Mavic Air no Detec Remote Control
489 7 2018-6-13
Lenin
Flight distance : 127943 ft
Dominican Republic
hello I have a problem and I want to share it with you to know how to solve it, I have a mavic Air that uses it on saturday June 9 all right and today when it was to fly I could not get the ship to connect to the control, download DJI asi 2 1.2 .4 the drone was updated, but still continues with the problem.
what do they say
2018-6-13
Optimus Prime-Mavic Air
Flight distance : 568704 ft
Vietnam
Did you try to manual connect drone with remote controller?
2018-6-13
Lenin
Dominican Republic
Optimus Prime-Mavic Air Posted at 2018-6-13 18:34
yes, pouse-FN + Sensor
2018-6-14
Vietnam
Lenin Posted at 2018-6-14 06:04
Did you try to connect at other place? Or change the band 2.4 or 5.8? May be some interference make issue happen. Last step is try to factory settings and refresh firmware of both drone and remote controller using dji assistant from computer. Hope this helps.
2018-6-14
Lenin
Dominican Republic
Yes, on Sunday I used it for the last time, yesterday I was at the beach and it did not work. I assumed it was something to go around the area, but when I got home, the problem prevailed. the control LED is always red in the control.
2018-6-14
Lenin
Dominican Republic
I've been seeing in the forums and I see several cases equal to conditions that happened to me before, I had two batteries, a low of 80% to 0% in less than two minutes and never I started, then started to disconnect and returned to home I just had to restart it , and now it is no longer connected, apparently it is something of application between the drone and the control
2018-6-14
Vietnam
That's very bad, if you on iOS then try to update to latest dji go and try again. Hope this issue is fixed
2018-6-14
Lenin
Dominican Republic
that's right
2018-10-3
