thephilz
Update on D500 (It's slightly more useable):- It'll actually go into live view now but it's stuck to the one you select (video or photo)
- Rec button on gimbal now works, BUT it always focuses before, no way to just record. It's kind of useless unless camera is set to manual focus (which prevents pull-focus)
- Pull-focus works, but is jittery, it's not smooth, and it seems to be large 'steps' nowhere near the fidelity of other tethering apps. Lens dependent on how bad it's impacted–
- Pull-Focus requires camera set to AF, but if set to AF, record button on gimbal ALWAYS refocuses
- No focus point selection, I also have no idea what point it's using, might be just full-auto
- Camera still locked out from any on camera control other than the live view switch
- App can't flip between photo/video (might be a hardware limitation of Nikon cameras)
- The display isn't your normal live-view display, shows no useable info
- -- Can't monitor audio levles
- -- Can't change a single setting (Aperture, Shutter, ISO, ETC; all have to be pre-set and 'right' before you plug the cable in...!)
- -- Can't review anything in playback (can't actually enter playback mode)
- -- Can't change any video settings or audio settings from the quick menu (Again, camera unresponsive to buttons)
Sooooo.... sure, it kind of works, but actual usability for video it's not any better than it was before. It's simply a great gimbal, no need to hook the cable, and feel free to remove the pull-focus. Which defeats the purpose of spending the cost on it when their are cheaper alternatives.
What I don't understand is the inability to work with DJI / their engineering team on how this needs to work to be useable; they need to work with the professionals that actually are going to be using it. It's what I do with both RED (we've even had their guys fly out and join us on shoots) & a lesser extent Nikon. I get no-where with Email support, they even said I could return it if it was within 14 days as if I got it from DJI (but I ordered via B&H, they know this as required proof of purchase), it's a bit, sad.
Needless to say I'll be putting together a comprehensize review and putting it up on our groups YouTube. This is totatlly inexcusable, and everyone needs to know.
