jermsmorton
I have discovered an actual fix for this. My Nikon D500 was having the same issue as everyone else connecting to the RSC2. The feed on my phone from the RavenEye would only show up if my camera was in Live View mode (using the screen on the back instead of the viewfinder), but when i connected the control cable from the gimbal to the camera, Live View would switch off, the screen shows "PC," and Live View would not come back on with the cord connected. Also, REC button the gimbal did not work, even when connected.
On a whim, I tried connecting the USB3 cord my Nikon shipped with to the gimbal's control port using a USB to USB-C adapter that i had from an old phone. When that is connected, Live View can be switched back on, enabling the feed on the phone. (Luckily it can be switched back off afterward without interrupting the feed, saving battery life on the nikon). Anyways for whatever reason, with that cord and adapter, the REC button on the gimbal functions properly.
I hope this helps, and it sucks that I'm typing this a couple years after you all were working on it.
Cheers. |
