Brad Bilger
Flight distance : 14843274 ft
randy.sauder Posted at 2018-7-1 20:34
I disagree. Your input may help a lot of people b/c this problem is very common, so anyone who helps out with this (even theories to fix) is better than DJI that goes at least 9 months of this problem without any improvement (in fact I see its inflicted Mavic Airs big time too now).
C'mon back
Thank you... This morning, I did an experiment. I have three batteries.
Battery #1 I took off, with no prep. I just took my Note 5 and clipped it in the holder, plugged it in and took off. I had stuttering. About once a second, it would hesitate. Totally different from what I usually get.
Battery #2 Before I took off I went through Device Maintenance. I shut down all background apps. Unloaded my CPU usage and extra battery Load and demand as I've described above. And then took off again. This time, the stutter was only about once every 15-20 seconds. Entirely acceptable. One little bump occasionally.
Battery #3 This time, I also switched my phone to Airplane mode. NO stutter. NO lag. NO issues. Crystal clear video signal. No problems other than the wind that was starting to pick up.
Randy, I thank you for your comments. There is enough anger and frustration on this forum especially in some of the other threads and I do NOT want to be a part of that situation.
What I do, works.... and if it helps others, then great, we have done what the intent of this forum is here for. If it works for someone else, wonderful. I am happy to help them. If it doesn't work for Apollo580, my condolences. If someone doesn't like my advise, then they can simply ignore it. No skin off my back. I"m only trying to help others.
Just because someones advice doesn't work for YOU, doesn't mean that it won't work for someone else. |
