3-D
Flight distance : 635764 ft
JPrad Posted at 2018-6-14 06:23
Thanks A CW, Yeah, I've been viewing them through the DJI album and also my samsung gallery app (as it saves to my phone). Its being taken on the internal 8gb SSD until my micro 124gb arrives.
Thanks for your suggestion, I'll take the photos using my old iphone as above, and see if that resolves. If not, ill upload directly from the SSD (view on my pc) and to this forum.
I think that if you view the pictures from your phone, you are not looking at the actual aircraft photos.
You should pull the SD card from the aircraft and take a look at them. Or, plug the aircraft into your PC with the included USB-C cable and import the photos from the aircraft. I'm pretty sure it will be better.
Also, make sure that you're using a compatible SD card in the aircraft that is fast enough to write at the speed the Mavic Air wants to write.
Hope you're able to get it sorted!
