ThinAir
Flight distance : 659150 ft
DJI Natalia Posted at 2018-6-15 05:27
The Forward, Backward, and Downward Vision Systems can be calibrated with DJI Assistant 2 and DJI GO. If there is an error with the Forward, Backward, or Downward Vision Systems, a prompt stating that auto calibration for the Vision System is required will pop up in the DJI GO app. Follow the instructions in the DJI GO app for calibration. It is recommended to calibrate the Forward, Backward, and Downward Vision Systems with DJI Assistant 2. If you don't have a computer at hand, calibrate them with the DJI GO app.
Thanks Natalia for your quick reply !
I did calibrate hte Forward + Downward Sensors with Ass2. It did work. But how to calibrate the Backward Sensors ? The only way is through Go 4 app. Tried it 5 times to na avail. But on 2 occasions, the app prompted what seems to be a quick message looking like it has worked out, but, as I said, the message lasted only a few seconds. And then, the app tells me to calibrate through Ass2, wich cannot calibrate Backward Sensors !!!
That is where I'm stuck, for now !
p.s.: When I try to calibrate the Backward Sensors with the Go 4 app, I tap 'Calibrate' and then the app show s how to move the AC: holding the AC at arm's lenght, drawing a square. The back LED on the AC blinks red when it doesn't work, then yellow when the app is calibrating the sensors. When I finish the calibration with the LED blinking red, calibration fails, but twice, the app managed to finish the calibration with a yellow blinking. And that'a when I get the really quick message in the app. But it goes to fast, then I get the 'Try to calibrate through Ass2' message.
Hope that it helps you to guide me on the right track !
Thanks ! |
