paul2660
Flight distance : 10331 ft
The Phantom will do best in the aperture range of F 2.8 to F 4.5, 5.6. F11, way to small and will have diffraction issues. Diffraction = softness.
If you are shooting jpgs, you need to add sharpening to the process, you have 0, +1, +2 +3 for settings, I would at least have +1 maybe +2.
Personally, I would recommend raw, a bit more work, but much much more leeway with the files, especially the sharpening. Jpg all processing is being done by the processor on the drone. These just so much more room for raw/dng in post processing.
Also, focusing. I will use AF to hit a spot in the distance to set my focus, then move to MF an stay there.
DJIGO4 with the Mavic (I understand this is Phantom) will sometimes attempt to refocus on hover. If the drone picks sky, it' won't lock and will odds are be out of focus. Not sure if the Phantom does this also, but no reason to stay on AF, once you have a lock and have focus.
You can also supposedly half press the shutter button the controller to get a zoom feature, I have not tried it.
Paul Caldwell
