hi, as it says.... I bought a new inspire two, as soon as I got it I did the firmware update, went to calibrate the compass but the button isn’t there... the compass bit is but calibration isn’t so how Can I do this without the button.
Hi. Thank you for raising your concern to us. I understand that you want to calibrate the compass of your DJI Inspire 2. I will be very glad to help you with this. I will be posting an official DJI video tutorial on how to calibrate the compass of your Drone. Hope this can help.
DJI Stephen Posted at 2018-6-16 12:51
https://www.youtube.com/watch?v=7CTpR78KcoE
I know all this but as I’ve put in my first post, the calibrate button isn’t there, so how Can I calibrate with out it?
Cdo1uk Posted at 2018-6-16 12:53
May I know what is the model of the mobile device that you are using. To check if there is a compatibility issue.
DJI Stephen Posted at 2018-6-16 12:58
I just checked my Crystalsky and its in the same as my iPhone. Go into advanced settings, sensor state and there will be IMU and Compass , press compass and there should be a blue Calibrate Compass.
Jbundy63 Posted at 2018-6-17 06:16
Did you try checking in the aircraft status bar instead of advanced settings.
