MP Platinum Battery Compatiblity
796 11 2018-6-17
AnDiego Air
Flight distance : 240702 ft
Hi guys
Anyone try using the regular MP batteries with the MP Platinum? Wondering if they will work
Thanks in advance!
2018-6-17
HereForTheBeer
Flight distance : 5381368 ft
yes, only difference is color
2018-6-17
AnDiego Air
HereForTheBeer Posted at 2018-6-17 17:58
Thank you First Officer!
2018-6-17
Lucas775
Flight distance : 50642090 ft
They are identical (-color) batteries.
2018-6-17
sanuk
I can report that the Platinum batteries work fine on the regular MP, so it is a pretty safe bet that the MPP and MP batteries are identical.
2018-6-17
davidmartingraf
Flight distance : 106566408 ft
I do not have a Mavic Pro Platinum and haven't tried the battery compatibility. I've seen information by DJI and other independent testers that both batteries are compatible with each other.
2018-6-17
DJI Stephen
Hi. Thank you for raising your concern to us. I understand that you want to know if the DJI Mavic Pro battery is interchangeable with the DJI Mavic Pro Platinum battery. Yes, they have the same specifications the only difference is the color.
2018-6-18
A CW
Flight distance : 13864580 ft
They are exactly the same except the colour. The increase in flight time on the MPP is driven by the new ESC's and props lowering the motor RPM's
2018-6-18
AnDiego Air
DJI Stephen Posted at 2018-6-18 06:33
Thanks!
I understand the MPP has a longer battery time, so obviously wont apply if you use the older MP battery correct?
2018-6-18
AnDiego Air
A CW Posted at 2018-6-18 07:16
Great to hear, so we can still use the old batter and gain the longer flight time!
2018-6-18
A CW
Yep - MP battery in MPP same flight time as MPP battery
2018-6-18
DJI Susan
AnDiego Air Posted at 2018-6-18 10:13
Thanks!
Both the battery capacities are the same. As mentioned above, the flight time extends due to the imp[rovements on ESC technology and propellers.
2018-6-19
