gnirtS
Flight distance : 5712575 ft
Ive had mine 12 months and its "used" but fine. The issues ive had:-
Ive broken 3 of the protective plastic dome covers so far (the lugs snap off all the time).
The zip on the front compartment of the flymore bag has snapped (i crammed too much stuff in it).
2 out of my 3 batteries have noticeably swollen (roughly 63 charges on each).
And thats pretty much it, a few scrapes and insect smears on the casing. I changed the props last week to new ones for no other reason than i thought after a year i should change them regardless of any damage and props are cheap.
The drone has its own "personality". Like a lot of them, the one side of the image is really soft around the edge so needs to be cropped quite often and it has gimbal or yaw drift in the air but you get used to those issues.
Most of its flying is in extremely hot and humid tropical environments, around rainforest or very close to and over salt water and its handled it nicely.
And i always use the gimbal clamp, its the last thing to remove before powering up and the first thing fitted after powering down even if i am flying immediately again.
