KlooGee
Flight distance : 16783757 ft
I agree largely with Mirek6's analysis of the flight. Unfortunately, none of us can know for sure what was the reason for the YAW errors, but I have always assumed the same as Mirek6 in regards to something going wrong in the system and causing different sensor systems to provide conflicting data and causing it to drop into ATTI mode. I also agree that it is very likely that the issue started happening before the Spark's logs actually started indicating there was a problem. You can see it in the video start to get a bit "slippery" in its movements and not being steady like expected when in full control.
In regards to the "Weak GPS Signal" message at 1:21.5, that is a direct result of the action taken and logged at 1:17.1 where it exited GPS mode and started ignoring all GPS data as far as navigation goes. I agree with Mirek6's latter thought on this rather than it having anything to do with satellite geo-spacing or anything directly to do with GPS specifically.
Where I do disagree with some of the thoughts expressed in this thread is that although control in ATTI mode is difficult, from my perspective, the Spark responded to all stick inputs from the pilot and gave corresponding movements. When yaw inputs were given to the sticks, it yawed appropriately. When roll inputs were given, it rolled appropriately. I think where a lot of people (even very experienced pilots) misunderstand and think its not responding is because when the Spark is in normal mode, it is like driving a golf cart. In a golf cart, full throttle is still not that fast and most of the time the top speed is governed to something very slow. In normal mode (especially with obstacle avoidance turned on), the Spark's speed is severely governed. However, when it kicks over into ATTI mode, your golf cart immediately transforms into a race car with no brakes.
So in this instance, at 1:04.1, the pilot did a full right stick backwards to move the aircraft backwards at full speed. While it was in GPS mode, it resulted in a golf cart slow speed. However, when it flipped to ATTI mode at 1:16.0, the golf cart transformed instantly to the race car with no brakes and accelerated from under 5m/s (under 8mph) to over 16m/s (36mph) in just a few short seconds. Once the right stick was released, it stopped accelerating and started slightly decreasing its speed until it was flipped into Sport mode and regained its composure and immediately hit the brakes to slow it down.
I'm in no way blaming the pilot for this because it is impossible to react instantaneously. Just trying to explain the behavior I see. In spite of the pilot feeling like they have no control, they actually do have way more control than they think.
In this particular case, it was great thinking by the pilot to flip it into Sports mode so quickly. This isn't the first time I've seen Sports mode help a pilot get an aircraft back under control. Not sure it will help in all situations, but in my opinion, definitely something to potentially try when in a bad spot.
Glad you were able to get your Spark back! I hope DJI can investigate and understand what the root cause was and create a solution to prevent further occurrences!
