Crystal Sky Mount for P3S
1873 9 2018-6-18
JSKCKNIT
Flight distance : 1208566 ft
I was flying yesterday in the full sun, could barely see my ipad screen or my phone screen even with the hood and brightness all the way up.  I switched to flying my Mavic Air and could see everything on the Crystal Sky perfectly fine.  I tried my crystal sky with the P3S and it appears to work fine, I only changed the camera settings.
My question is, has anyone modded their P3S controller to accept a crystal sky mount?
Thanks in advance.
2018-6-18
DJI Stephen
Hi. Thank you for raising this concern. I understand that you are looking for a mount for your DJI Crystalsky. Let me help you with this. I will be posting a link where you can see a mounting bracket for the DJI Crystalsky on your Phantom 3 Standard Remote Controller.
https://store.dji.com/product/cr ... ion=2&vid=23531
2018-6-18
JSKCKNIT
DJI Stephen Posted at 2018-6-18 06:11
https://store.dji.com/product/crystalsky?from=search-result-v2&position=2&vid=23531
Thanks for the reply.  I just want to confirm this will work with a P3S, even though it's not on the compatibility list?  I realize the controller may need a hole or two drilled.
2018-6-18
DJI Susan
JSKCKNIT Posted at 2018-6-18 06:20
[view_image]
Theoretically speaking, they are not compatible as there is still no mounting plate for P3S for now. We'll release on our website as long as there is an update. Thanks for your attention.
2018-6-19
JSKCKNIT
Just had to carefully drill one hole. Mounted perfectly. I thought about removing the USB cable, but I may use the mount on a different controller in the future.
2018-6-23
Eric13
Flight distance : 13982031 ft
JSKCKNIT Posted at 2018-6-23 12:47
For what do you have all these stickers on your remote?
If you need to look at these stickers to remember what sticks and switches are good for you may run into problems soon.
Just kidding - Altzheimers is getting to a lot of us sooner or later ;-)
2018-6-23
JSKCKNIT
The stickers were on there when I bought the P3S used a year and a half ago.
2018-6-23
Anonymous1
Flight distance : 602303 ft
Jamaica
If one uses a Crystal Sky, does one still need a phone or tablet paired to the transmitter to manipulate the on-screen features?
2018-9-3
JSKCKNIT
Anonymous1 Posted at 2018-9-3 12:41
Nope. The Crystal Sky monitor has the Go 3 and Go 4 apps installed.  All the features are the same.
2018-9-3
Anonymous1
Jamaica
That's a dream come true then.  My one hesitation is the initial cost of the Crystal Sky unit.  You already have one, so it is of no additional cost to you.
2018-9-3
