paul2660
Flight distance : 10331 ft
djiuser_UZ07584ef4Vm Posted at 2018-6-18 09:57
The firmware version from the Go4 app shows 1.00.1000. No response from the Assist; it doesn't show any version. Is that the latest?
I can send before and after pictures from last Thursday and this morning, if that helps.
Assistant 2 for Phantom, will not show any firmware. DJI's pat answer on this is that since only the base firmware is out there, the app will not show anything. (I don't agree with this logic, the base should still show).
I am also surprised that DJI on this post is asking if the firmware was current, as there is only the original firmware available. So there is no other firmware to have.
Back to the camera issues.
If you have reset the camera and re calibrated the gimbal and images are still out of focus not sure what else there is to check. You might try setting up the drone about 15 to 20 feet away from a wall, brick is best and just see if it can focus on that. You also might try manual focus, I realize it's not an easy process in flight, but just a thought. The fact that the camera was working at first does seem to imply that the drone may need to go back to DJI repair.
Paul Caldwell
