Power a iphone how?
885 10 2018-6-18
Dave_bass5
DJI seem to make a big deal of the fact that the Osmo 2 will also power the phone, but how on earth can it power a phone like an iPhone, were the charging port is at the bottom?
Just wondering.
2018-6-18
DJI Tony
Hi, Thank you for bringing your query here in DJI, it’s possible to charge your phone using the port at the back of the hand-held, we do have a tutorial for this kind of concern. Please see the video below so that you can check on how you’ll charge your phone with Osmo mobile 2.
2018-6-18
Dave_bass5
Lol, i know where the port on the Osmo is, but how can you power and use a phone in the Osmo at the same time? Seems to be a bit of artistic licence in the description for this device.
2018-6-18
Skewif
Only way I have found is a 90 Deg connector and a power bank. Go app is ridiculously power hungry, the bigger the power bank the better.
2018-6-18
kbm79
Dave_bass5 Posted at 2018-6-18 11:23
You can't charge your phone AND use the OM2 at the same time.
You will need a seperate battery charger for that.
2018-6-18
Swedrone
Flight distance : 14066975 ft
Sweden
Skewif Posted at 2018-6-18 16:17
Only way I have found is a 90 Deg connector and a power bank. Go app is ridiculously power hungry, the bigger the power bank the better.[view_image]
I use that one works perfectly while using the Osmo at the same time, my cable is dark gray however I think it´s the 4K recording that is rediculously power hungry - try without the OSMO and you will see.
2018-6-19
Mars5150
Flight distance : 391493 ft
Swedrone Posted at 2018-6-19 04:26
"...I think it´s the 4K recording that is rediculously power hungry - try without the OSMO and you will see.
What do you mean by this??
2018-6-19
Swedrone
Sweden
Mars5150 Posted at 2018-6-19 06:38
It´s not the Go app that drains your battery. Check the power statistics on your phone
2018-6-19
Magelis
Lithuania
I just put the phone a bit to left and put the cable and use it with cable connected.
2018-6-19
LouisP
Flight distance : 41952 ft
kbm79 Posted at 2018-6-18 22:28
I do it all the time... Plug the phone into the OSMO USB port and go.
2018-6-19
LouisP
Buy a right angle lightning cable and just mount the phone a little to the left to make room for it then re-balance the osmo.
2018-6-19
