Labroides
Flight distance : 9991457 ft
p56 of the P4 manual, p57 of the P4 pro manual
... tells you when you need to calibrate the compass
Only calibrate the compass when the DJI GO 4 app or the status indicator prompt you to do so.
If you ever think the appis advising you to calibrate .. it probably isn't.
In at least 99% of times people think it is, the correct action is to move away from the magnetic problem the compass is warning about, not to recalibrate.
The message wording is confusing.
It says move aircraft or recalibrate compass and no-one notices the first part.
The only time you really need to recalibrate is if you modify the Phantom by adding or removing equipment.
