paul2660
Flight distance : 10331 ft
DJI Paladin Posted at 2018-6-19 08:17
Hi Billy, Our apologies for the inconvenience. Please try to restore the factory defaults and refresh the firmware using DJI Assitant 2. Please download the software using this link: https://www.dji.com/phantom-4-pro-v2/info#downloads. You can also reset the factory default of your camera. Look for the cogwheel, scroll down and reset camera to factory defaults.
In this POST, DJI is referring to the software for the P4 Pro Vr 2.0 as "Assistant 2".
That is incorrect, and has been stated incorrectly on this site many times.
If DJI is going to rename a program and release is, they IMO need to refer to it with the correct name.
In this case Assistant 2 for Phantom. Which BTW is a confusing name as it by name implies it will work with all Phantoms, which is not the case.
In the Link provided on quoted post, DJI is correctly point to the correct download, but referring to the older software. This has caused a lot of confusion with owners of both the earlier versions of the Phantom and new owners of P4 Pro Vr 2.0.
The fact that DJI is asking the owner to connect and refresh the firmware via the Assistant 2 for Phantom software is concerning to me as currently you can connect, but the tool WILL not load current firmware and thus can't refresh the firmware since it won't load the current version . Per DJI is because there is only the original base software available for the P4 VR 2.0, so it can't load. I also don't agree with this, as you still should be able to "see" the current firmware installed on your drone, i.e. to be able to refresh it.
It's quite obvious that the DJI person making this request has never worked with Assistant 2 for Phantom as they would know currently you can't refresh firmware. All you get is the error Firmware can't be loaded, please retry".
Paul Caldwell
