Trackimo Mini
1172 14 2018-6-19
Steeevo
Flight distance : 264882 ft
Anyone using this tracker. It is the smallest gps wifi tracker out there and from a solid company who have a few trackers in the market.
Cant find any reviews about it and was hoping someone has one. Its 2g with wifi and comes with an unlimited lifetime service plan, i have ordered it so hopefully its good.  Its so small at 39mm i think will fit on the mavic pro alot better than the bigger square trakimo that most people use.
2018-6-19
Montfrooij
Flight distance : 2560453 ft
We need to remain VLOS, so I hope I won't need them
2018-6-19
Montfrooij
And by 'we' I mean in NL.
2018-6-19
Steeevo
I always keep vlos. But if anything happened like a flyaway i could retreive it.
Also you can use it for tracking anything i.e luggage, car, pets and my beautiful toddler
2018-6-20
A CW
Flight distance : 13877205 ft
Not personally but I have been told they work.
2018-6-20
DJI Stephen
Hi. Thank you for sharing this information. This device is a good way on how to track your drone. Just a reminder if you will be putting this device on your drone it will add weight and it might affect the performance of the drone in flight. Thank you.
2018-6-20
Steeevo
It weighs 20grams. I cant see that doing much to the performance of the mavic pro
2018-6-20
SparksBird
Flight distance : 10731690 ft
I believe that QuadKid here on the forums is using this.  I believe his is the square one.  Will try and find his thread for you and link it here.
2018-6-20
SparksBird
Check this out.  https://forum.dji.com/thread-150650-1-1.html
2018-6-20
Steeevo
Thanks for that link. This tracker is alot smaller than that.
Only thing you lot in the usa need to make sure you get is a 3g tracker as 2g is not available much now
2018-6-20
Steeevo
Here it is. Has been very reliable down to about a meter away and also has bluetooth when you are within 10m then gives you a radar as you get closer. Pretty happy with it so far
2018-6-27
hallmark007
Flight distance : 9827923 ft
If it contains metal you may need to calibrate compass with it on, keep it on the front as you have it, do not put on rear of Mavic as you will block gps signal.
2018-6-27
Steeevo
Thanks for the advice, I only put it there as it wont fit anywhere else unless I can find a mount or get one 3d printed, ended up using industrial strength Velcro
2018-6-28
Urban Mayhem
Flight distance : 1608 ft
Hi Steeevo, I am thinking of purchasing one of these myself. Have you had any issues while using?  Does the industrial velcro hold it secure?
Many thanks
2018-9-17
Steeevo
Velcro is super strong and i have no worrys of it falling off. I have used the little pouch they give you and used velcro to attach that the drone the. I can remove the tracker and leave the pouch on the drone.  The tracker fits very snug in aswell. I calibrated the mavic and have had no issues with it. I use it for my mavic and also on holidays with my little boy. I put it in his pocket if we go out
2018-9-17
