Lost my Sparky in the deep blue sea
1121 12 2018-6-20
deMarco73
Flight distance : 53675 ft
Dear all,
Today I lost my beloved Sparky in the deep blue water of Lake Garda. OK could be a more worse place than that, but in the end I lost her...
First I thought it was a pilot failure doing a Circle quick shot flying to low, so that the Spark strikes some kind of long antenna on top of a mast. We (a friend of mine was preparing his Mavic Pro to fly together) saw that in the distance two parts were falling down from the sky into the water.
But in the flight log there is nothing (http://www.phantomhelp.com/logviewer/U4LURYTFQGEJQND6BD2Y/) saying collision, engine failure or similar. So now I think that the battery ejected during the flight.
What do you think?
BR
  Marco
2018-6-20
DJI Tony
Sorry for the lost drone, I would suggest syncing your flight records via DJI GO 4 app and contact our facility for further investigations as well. Please see the link.
https://www.dji.com/support?site=brandsite&from=nav
2018-6-20
pmshop
Flight distance : 8073271 ft
That is exactly why you should have a spotter.
The observation may shed more light to the situation than the log.
I was first thinking the water screwed with the Visual Positioning System (VPS) and it dove in.
But at almost 30ft, it would have logged the decent no matter how fast.
I can tell you ejecting the battery is getting rare now but not totally gone issue.
2018-6-20
djiuser_uMitnAZejgn9
Flight distance : 10876 ft
Man that sucks lesson learned from some one else
2018-6-20
S.J
Flight distance : 322454 ft
Kuwait
its very difficult to control the number of incidents related to battery ejecting during flight.
The best way is prevention by checking that the lock mechanism is in tact prior to flying !!
2018-6-20
Flighty
Flight distance : 1977175 ft
Croatia
Seems like it could be the battery ejecting,, Flight Logs will definitely determine if that is the case!!..
2018-6-21
JJBspark
Flight distance : 12717890 ft
Hi deMarco73,
Had a look at your flight, looks OK with no errors etc.
On the chart you see that VPS height 'bump', flying over that harbour "dam" (what is te right english word?)
If the battery drops out than the flightrecord stops, so guess that is the case. If you hit something than you see blocked motors and high pith and roll angles.
So batt eject yes, but that normally happens in sport mode with high speed variations and drone angles. But you did see 2 pieces falling into lake-garda so 99.9 % you know the cause.
Guess DJI will sort this out for you in a good way.
Cheers
JJB
2018-6-21
Firehawk989
Flight distance : 198904 ft
If it dropped in the marina as shown on the map, the water there shouldn't be too extremely deep. Get yourself fins, mask, snorkel, and wetsuit if the water is cold and do some diving off the end of that dock!
2018-6-21
strixaluco
Flight distance : 463461 ft
Hi Marco, I agree with JJBspark, 99.9% it is the battery which got accidentally ejected. This happens if you have had a crash and the little hooks which hold the batteries are worn or broken.
Mi dispiace Marco in bocca al lupo per il tuo prossimo Drone (good luck for your next drone)
Btw, they sell a battery holder for the Spark for a few quid on ebay
2018-6-21
Northwood
Flight distance : 2148596 ft
Sorry to hear this loss....  and it reinforces my desire to avoid water.  I have the battery strap too.  Hope you get some resolve.
2018-6-21
DMX_MT
Malta
Ciao deMarco ! If two parts fell in the Water, its most probably is the Spark Body + Battery. Next time use Battery Retainers.
If you have Video Cache footage you will see a Disconnected Video, resulting in No Power to the Spark, which means the Battery Popped Out and the Spark became a Brick !
Just go near the Marina and if you can swim dive for it, else if you see a diver tell him to get it for you. Then send it to DJI. I would open a Case and tell them what happened !
2018-6-21
deMarco73
Dear all,
Thanks for the sympathy and the valued assessments! The cached video also highlights the assumption of ejection. Smooth circle path around the lighthouse with focus to it and suddenly stops. Otherwise there would be some struggling and the dive into the water would be recorded, but nothing.
If you are interested I could share it, but nothing special to see...
I'm already in contact with the support.
Grazie mille
  Marco
2018-6-21
DMX_MT
Malta
deMarco73 Posted at 2018-6-21 11:24
Dear all,
Speriamo bene Marco !
Tanti Saluti Bello !
2018-6-21
