Cannot connect to iPad Mini
1615 15 2018-6-20
rfcphoto
brand new Phantom 4 works great with iPhone 7 but will not connect to ipad mini using ios 11.0.3 tried everything need help
thanks
2018-6-20
Nigelbrinkmann
Flight distance : 586391 ft
Hi, need a bit more info, like how old is your ipad mini, dose the app load on the ipad/, is it a green screen? how may applications are on your ipad, are they all closed while trying to open DJI app, the DJI app requires a lot of processing power to operate it.
2018-6-20
ALABAMA
Flight distance : 10442687 ft
The GO4 app has gotten pretty power hungry.
2018-6-20
rfcphoto
Nigelbrinkmann Posted at 2018-6-20 17:47
iPad mini is refurbished just purchased it, app loads no problem, I closed all apps on the iPad I only added about 6 other apps to it
2018-6-20
rfcphoto
rfcphoto Posted at 2018-6-20 17:55
I researched and it says the app would work on iPad mini
2018-6-20
Nigelbrinkmann
How much total memory dose your ipad have?
2018-6-20
rfcphoto
Nigelbrinkmann Posted at 2018-6-20 18:14
32 GB
21.49 GB available
8 Applications
2018-6-20
Mariuss
Flight distance : 2480515 ft
Norway
Have had the same problem as you on the mini4. Can you get through to the main flying interface with the grey grid background?
2018-6-21
rfcphoto
Mariuss Posted at 2018-6-21 00:56
gets through to main screen no problem just won't connect to drone, if I plug in my iPhone it connects immediately
2018-6-21
ATJ
Flight distance : 17736 ft
rfcphoto Posted at 2018-6-21 03:23
Have you tried clearing the iPad Mini and restarting DJi Go 4 app making sure you are loading the correct Phantom 4 on the top left hand corner?
2018-6-21
rfcphoto
ATJ Posted at 2018-6-21 04:01
what do you mean by clearing?
2018-6-21
ATJ
rfcphoto Posted at 2018-6-21 15:32
Turn on the iPad as normal. Then tap twice quickly on the home button, then swiping all running programs off the screen. This will clear the iPad memory and allow you to start the app from the beginning. Then choose your Phantom in the top left hand corner of the startup page.
2018-6-21
rfcphoto
ATJ Posted at 2018-6-21 15:56
yes I've done that several times, still doesn't work
2018-6-21
ATJ
rfcphoto Posted at 2018-6-21 16:18
Have you tried choosing different Phantom 4 models on the App?
2018-6-21
rfcphoto
ATJ Posted at 2018-6-21 16:39
no I'll try that out
thanks
2018-6-21
Mariuss
Norway
I see. Might be the female on the iPad then. Can it sync/transfer data to a pc?
I sometimes have to boot the whole system up and then plug out and then in the ipad for the interface to recognize/recieve feed.
2018-6-23
