GDL Posted at 2018-6-20 23:14
Did you see the status light on RC turn green to confirm it linked with MA? Are you using the original cable come with the RC?
hi, i used the original cables and rc and aircraft are linked. gimbal is useable but still the same issue cannot tap on "LINK WITH AIRCRAFT"
If you use the large USB below nedd to disconnect the cable on small USB even it didn't connect to anything.
Check is the phone on support device list. Try use another device to connect with RC to see is it work. You may need to send it back to if still not working.
GDL Posted at 2018-6-21 05:00
I can now use wifi. But still cant use remote. Any suggestions?
