tvscreen
Flight distance : 41430 ft
Please be warned that what DJI support tells you, may not always be true.
I am currently disputing this case and will make the results known as well.
Hopefully DJI looks and listens more closely to this problem, it can't be the only time this has happened...
CAS-1862460-M1C9R3
My 9 month old Mavic Pro was working great with no issues - then on a recent shoot in a clear area, it took off roughly. One of the arms seemed to start shaking and it made a hard right at about 10 ft and crashed lightly. There were no obstacles around for about 20 feet in circumference when it stuttered and crashed.
I cleaned it up, replaced some props and took off again - thinking, maybe a propeller was chipped or something. As before, it lifted fine, but at about 4 ft. or so, it shook and crashed again, cutting a hard right and landing on grass.
I examined it, tried one more time (on full grass), and the shaking happened immediatly. I knew I had to send it in.
It seemed maybe the front right prop motor (if viewing from behind), was having an issue and causing imbalance/crash. It also had some scrapes and bumps but nothing major that I could see. I had confidence in DJI, its products and services and expected they would hread my description, examine my evidence and simply fix the unit.
I supplied flight logs and all requested materials to DJI support and figured they would correct whatever made the flight(s) malfunction and do it under fairly under the warranty ...
Then they sent back the dialog below - which states I hit an obstacle and it caused the crash, user error. My fault... Not true even slightly.
Nothing would or could show such an obstacle hit or user steering error. No crash happened until the drone malfunctioned. Nothing was around me when my flight took off. Nothing even close. It just shook and pitched and crashed. No obstacle sensors went off. No wayward steering happened. I only lifted the drone straight up and it shook and came down. I did not even turn it, just went straight up. Every time.
I have included the correspondence that they sent me here:
NON-WARRANTY PER DATA ANALYSIS. User stick command error FLY112 1. Unit was in P-GPS mode and was responsive to RC input; 2. At t=00:16s, relative height=3.4m, unit recorded external impact, then fell. 3. User commanded left stick command during flight causing craft to strike obstacle. Incident date: 5-6-2018 Incident GPS location: 3.140506, -82.314099 Activation date: 9-23-2017 SN: 08QUE8C10100BL Conclusion: User stick command error. Impact in air. [Non warranty Repair] Dear Customer, Unfortunately, damage that is not caused by a product malfunction or is out of the warranty period is not covered by DJI aftersales policy. We will either repair it or replace it with a product that's new or equivalent to new in both performance and reliability after payment has been received. For more information, please visit http://www.dji.com/service/policy
Just please be warned that what DJI support tells you, may not be true.
I am disputing this case currently and I will make the results known as well.
Hopefully DJI looks and listens more closely to this problem. This can't be the only time this has happened.
Rob Springer
Mavi Pro User
