bobo
Flight distance : 1544416 ft
What's New?
2018.06.20 V01.01.0911
V01.01.0002 V02.00.0090(Cendence) iOS V 4.2.16, Android V 4.2.16
Android V 0.6.1 V2.6.6.0
Fixed a bug where more or less photos are captured when both cameras simultaneously took photos in the dual downward gimbal configuration. (If Zenmuse XT is used, please attach the Zenmuse XT with the XT Adapter together to the Gimbal Connector I, and use the DJI Assistant 2 for Matrice software to update the XT Adapter.)
Optimized the Unlocking feature for GEO System.
Improved the return to home and landing accuracy of the M210 RTK.
Fixed a bug where prompts failed for flight limits and unlocking.
Fixed a rare bug where “IMU abnormality, please calibrate the IMU” appears during turbulent flight.
Fixed a bug where aircraft and gimbal problems happened when the X4S\X5S yaw rotation is reversed
with the aircraft. Note that the X4S\X5S should be attached to the Gimbal Connector I when updating.
Fixed a bug where the aircraft distance incorrectly displayed in app when exiting flight from the
simulator.
Fixed and optimized other issues.
