Litchi is a Bitchi
2724 16 2018-6-21
WeeAirDrone
Flight distance : 122159 ft
A short one this time everyone. A lesson was learned by me today. I used a mission prepared by someone else on Litchi Hub. I had an epic fail as it must have been created in the winter. The trees had grown somewhat since then and the WeeAirdrone had a fight with a tree. it escaped unscathed not even prop damage. My lesson for today is if you are using someone else's mission over trees put at least an extra 5 feet on each selected waypoint.
2018-6-21
Jotne
You should study it as you would create a new one.  There may be a new building as well.  Here I am now, there is a new skyscraper every week.
2018-6-21
FanOfFlight
Flight distance : 1983760 ft
Your height is set based on take of height also....   so, if you only have a few feet clearance, you will clip those trees based on sensor variance and take off height.
2018-6-21
FanOfFlight
Your height is set based on take of height also....   so, if you only have a few feet clearance, you will clip those trees based on sensor variance and take off postion (which sets your height).  If you need to use someone elses flight plan, run it really slow and keep an eye on it.  Stop it if it looks wacky.  I personaly would not use someone elses flight plan.  The main reason is you dont have the fly that plan before sharing it.  If you had to fly the plan before you shared it, it would reduce the possibility of someone lowering a point so the next person using it hits a tree.  I dont trust other people flights.
2018-6-21
Amateur Droner
Flight distance : 6411 ft
First create your own missions, then if you have a mishap you can only blame yourself.
Run the mission in "Virtual Litchi Mission Viewer"
Fly safe and enjoy!
2018-6-21
Chesysmax
Japan
Is Litchi reliable for making waypoints for Mavic Air? Thank you.
2018-6-21
saviour
Flight distance : 604203 ft
Chesysmax Posted at 2018-6-21 21:51
Yes it is as with other drones. I purchased Litchi last week and it works just fine.
You have to be careful though, as the waypoints are not exact. I was once surprised as the drone started 1-2 meteres apart from the initial point I programmed. So don't put waypoints close to objects.
Also what bothers me with Litchi is that setting up the controller in Litchi always changes my settings in DJI Go 4 (left C button suddenly opens camera settings instead of resetting the gimbal as I set it up to)
2018-6-21
sky6105
Flight distance : 345653 ft
Litchi is a good app but you better know your surroundings. I also learned it the hard way came out untouched after it fell from the tree.
If you can run it manually do it, if not add some height to your flight. After that I have had no problem with Litchi.
But my go to is GO 4.
2018-6-22
WeeAirDrone
FanOfFlight Posted at 2018-6-21 18:57
Great point absolutely right this was my first use of someone's flight plan I have several plans of my own all perfect. It was a lesson learned and maybe I need to take your advice on board.
2018-6-22
WeeAirDrone
It is I have had huge success using the litchi Hub to set waypoints and creating some great object focused film. I tend to practice with it in the local park, where there are no obstacles. Height is your friend with the app though always be cautious if in doubt add 10 feet
2018-6-22
FanOfFlight
WeeAirDrone Posted at 2018-6-22 00:50
Thanks and Good luck.  I have learned many lessons the expensive way so glad to share  what I can.
2018-6-22
A CW
Flight distance : 13877205 ft
Hahaha - that's a good pay of putting it
2018-6-22
Free2be
Flight distance : 229570 ft
Nice video follow the other bird!
2018-6-23
DJI Stephen
Hi. Thank you for raising your concern to us. I understand that you use the litchi application DJI Mavic Air and you almost damaged your Drone. We do not recommend to use 3rd party devices or applications like the litchi on your DJI Mavic Pro because 3rd party devices and application can affect the performance of the Drone while on a flight. Please use the DJI Go 4 application. This application was made for your DJI. Thank you.
2018-6-23
Optimus_Prime
Flight distance : 568704 ft
Vietnam
DJI Stephen Posted at 2018-6-23 07:06
I wonder why do DJI not include waypoints and up/down hill following for the air? So we do not have to use 3rd application.
2018-6-23
North Idaho Guy
Flight distance : 2310082 ft
I didn't realize that DJI's Go 4 (used with Spark, MA for example) could do what Litchi (used with Spark, MA for example) can? For example, plotting a autonomous mission on specific routes, setting different camera views at POI fly by's, waypoints to waypoint height and speed selections, etc. , etc., etc......or am I mistaken that Go 4 can do all this with a Spark or MA? If DJI's Go 4 can do this, then heck yeah, no need to risk third party anything running on DJI drones........Or perhaps its just a disclaimer? If so, I get that too, total understandable.......
2018-6-23
Landbo
Flight distance : 502792 ft
Denmark
I have flown many missions with Litchi. If you do not get a mission correctly entered in terms of heights, it can easily go wrong. Therefore, the pilot's most important task is to control a "borrowed" mission before flying.
Fly safe, greetings Leif.
2018-6-23
