So i made my 1st flight with MA, i used my mobile (P20 Pro) for it, and after powering off for battery replacment i couldnt connect aircraft again cause it no longer broadcasts Wifi SSID.
The only thing that i found for temporary fix is is to connect Mavic to PC and "re-update" firmware with DJI Assistant.
Are you flying with your mobile device, if yes, why? Or are you flying with your RC (much better!)? If the latter is the case it is normal that the SSID of MA is hidden and you don't need it.
DJI Paladin Posted at 2018-6-22 03:59
Hi, sorry for the inconvenience. Can you clarify if you're using a remote controller or mobile device only to control the aircraft?
Yes, im trying with mobile phone only, i know that RC is better but this "feature" looks like a bug for me.
Wachtberger Posted at 2018-6-22 03:51
Mobile only, and why its hidden if theres a feature to use only your phone to fly? I know/belive RC is much better but dissapearing SSID after previously successful flight just bothers me and lokks like a bug.
PiVoR Posted at 2018-6-22 04:10
You can always reset the WiFi on your MA with the rear button (see user manual or the relating tutorial video for that). But I fail to understand why you don't use your RC...
Wachtberger Posted at 2018-6-22 04:51
Lets say i maximize portability, if my phone is enough to fly, im fine with it alone.
LoSBoL Posted at 2018-6-22 13:41
Hold the rear button untill the craft beeps three times and the SSID wll apear, I have the same issue when trying to connect with just the Phone.
Yeah, it helps, but seriously, having to reset wifi each time you want to use mobile is kinda dumb.
