How to disable video being saved on phone
8759 13 2018-6-22
djiuser_qRoypWAvl2W2
Flight distance : 673 ft
I followed the instructions, and disabled "cache to SD card" but the app is still saving a local copy. I tried stopping and restarting the app, but no change. So what exactly is being "disabled" when I uncheck "cache to SD card"? Every time I hit the record button, I am also seeing a local copy being saved. I am using the latest version 4.2.20
2018-6-22
S-e-ven
Flight distance : 5922034 ft
Thailand
Ever set the size of the cache to the lowest possible value?
2018-6-22
Antipaxi
Greece
There might be a video cache option in the DJI GO4 app. Me, Settings (little wheal in the top right corner), Clear cache. I cleared it as I got a video cache full message yesterday.
2018-6-22
Antipaxi Posted at 2018-6-22 22:12
I have my cache disabled, but it is still saving all the videos on the phone. What am I doing wrong?
2018-6-23
S-e-ven
Thailand
Can't tell, what you are doping wrong.
But in your case it might be better to try "on", with the 1G setting and NO AUTO CLEANUP
After the 1 G is full, it should stop.
You device is....?
2018-6-23
S-e-ven Posted at 2018-6-23 07:23
Device is Android Motorola G4.
2018-6-23
S-e-ven
Thailand
Actually, you could try to set the feature with an different version of the go4 app.
To check if that would switch it off!
2018-6-23
S-e-ven Posted at 2018-6-23 08:39
So where do I find the older versions? DJI website has nothing about it.
2018-6-23
S-e-ven
Thailand
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/
I would try 4.1.15 and/or 4.2.12
But I have never tried to stop caching
2018-6-23
JimboHUN
Flight distance : 37156 ft
Mine does the opposite - It is set to save but since the update to 4.2.20 it is not saving
2018-6-23
S-e-ven Posted at 2018-6-23 11:19
Is this a DJI-approved process? I mean, if the drone does something strange and crashes, would DJI say I am on my own for installing an unofficial apk?
2018-6-23
djiuser_qRoypWAvl2W2 Posted at 2018-6-23 13:54
Based on some older threads, it is not possible to disable video caching on the android. Is that still true?  https://forum.dji.com/thread-101075-1-1.html
2018-6-23
Vitoski
Flight distance : 23576 ft
djiuser_qRoypWAvl2W2 Posted at 2018-6-23 07:20
[view_image]
hi!
I have exactly the same issue - video cache option is disabled in the DJI Go 4 app, but each recording is saved to my phone... Tried already the latest version of DJI GO (4.2.21) as well as 4.2.12.
Not sure if this is related, but my video feed stutters while turning the drone. Does it happen to you as well?
UPDATE:
I think the "Cache to SD card" works as expected... It allows you to MOVE recordings from internal phone's memory to SD card. In other words if the option is turned on, you can select your phone's SD card for recordings, otherwise it will use the phone's internal memory.
That said - there IS NO way to completely disable saving recordings on your Android Phone. I tried this with version 4.1.15, 4.2.12, 4.2.21.
DJI do something about this. Your hardware is great, but the Android software - piece of ...
2018-8-12
DominikS66
Flight distance : 200568 ft
Try this: https://forum.dji.com/thread-169810-1-1.html
2018-10-19
