S-e-ven
Flight distance : 5922034 ft
RockytheSquirrel Posted at 10-3 12:23
Has anyone been able to confirm that the "bounce" only happens when you "slide to take off" in the app? And not when you take off with the RC sticks?
Out of experience, it worked for some time.
At least it was a workaround, and when it didn't work that well, with slowly starting via CSC, it worked with CSC start, but switched to sport after starting the motors, and trying to gain some meters, before the whh,...,whhh started. Last year in May I had almost every start this trouble, from "every 20ish" over "every 10ish" down to every/other.
For about a year now, after sending it in a third time, just before warranty end, it seems to be repaired and working (knocking on wood)
But yes, at least it will get you a chance to get it in the air.
With some meter under it, it always seemed to stabilize, even the times I had to "alarm start" it in sport mode.
And I still have the idea that it is a voltage thing, at least connected to, or the trigger for, cell deviation which shows up red, in the flight records. |
