Gimbal
639 19 2018-6-23
djiuser_SrrIUWy2ZhDK
Flight distance : 4442 ft
Turkey
Hi,friends
Today I have had an issue.I can not adjust gimbal values.On the remote control  I move the gimbal wheel but it does not command the drone.What should I do?
Is there any way to reset the gimbal values or how could I ajudt the values?
Thank you
2018-6-23
Turkey
Now it is clear that one needs to be rocket engineer to solve the problems of spark and its application.Does someone who has mental problems prepare these unfriendly software?
2018-6-23
S-e-ven
Flight distance : 5922034 ft
The gimbal is not moving up or down, when the wheel gets moved to the right or left?
Hold it longer or check in the app the gimbal settings.
Maybe your gimbal speed is at "1"?
2018-6-23
Turkey
I think in a very short time I will slam it to the nearest wall.
2018-6-23
Turkey
S-e-ven Posted at 2018-6-23 03:03
I tried a few gimbal speed values.10,50,100.
2018-6-23
Turkey
Hold it longer?What should I hold?the gimbal wheel?
2018-6-23
S-e-ven
Yes, the wheel.
Unless in 100, it may need a while to respond
Put the Gimbal up/down function on the one of the customizable buttons to check if the gimbal moves at all.
Is it resetting itselfs, when started the drone with the battery button?
And:
If on android, try an older Go4 app
It may be another bug in the app, settings for RC, me thinks
Oh:
Try this:
Start drone, rc, phone
When you have the cameraview on the display, place your finger on the display, too
A blue circle occurs around your finger
Move it down and /or up
What happes now?
2018-6-23
Turkey
S-e-ven Posted at 2018-6-23 03:15
Yes, the wheel.
Thank you.It is charging now,later I will do what you say.Thanks
2018-6-23
S-e-ven
Thailand
Good luck!
And just to be sure:
"On the remote control  I move the gimbal wheel but it does not command the drone.What should I do?"
The gimbal wheel is for up/down movment of the gimbal, not for left/right movement of the drone, if in the air!
2018-6-23
Turkey
Yes, the wheel.
By the way,How can download an older version?On Google Play there is only dji go 4 for drones since p4
2018-6-23
Turkey
Yes, the wheel.
I tried,everything sucks againAnd it happened itself.I don't think I changed anything.
If there is college to learn spark,I should register.I wish I hadn't bought it.
2018-6-23
S-e-ven
Thailand
Mate, you are not getting the best help b/c/ you are not giving the best informations!
Pair your phone with your Spark and test the gimbal moving there.
You can test your gimbal on the desk, you know that, right?
No flying needed!
Report back, please
2018-6-23
Turkey
S-e-ven Posted at 2018-6-23 04:52
Dear S-e-ven;
Believe me I tried many things.At first,in the morning there was no problem.Then I noticed that the gimbal moves only a little.I tried to change some gimbal values but the problem continued.I put a gimbal guard,I thought it might be the reason,I took it off.
I tried it both in the air and on the desk.
Thank you for your interest
2018-6-23
Turkey
djiuser_SrrIUWy2ZhDK Posted at 2018-6-23 05:18
Dear S-e-ven;
When I connect to spark without combo,it is ok.Now I am trying with combo.
2018-6-23
S-e-ven
Thailand
Try without phone connected and try with phone connected
And try with putting your finger ON THE DISPLAY and moving it up and down
Would help a lot to verify that the RC is the problem.
Have You used a OTG cable, lately?
Last time you did fly, did sport work?
2018-6-23
Turkey
djiuser_SrrIUWy2ZhDK Posted at 2018-6-23 05:21
Now it refuses to connect combo,even though I followed the same steps.Number one problem creator.
2018-6-23
S-e-ven
Thailand
2018-6-23
Turkey
S-e-ven Posted at 2018-6-23 05:45
https://youtu.be/GOi9WiS-PF8
Thank you I know how it is done but it sometimes doesn't work.But it is ok now,thanks again
2018-6-23
S-e-ven
The gimbal problem too?
2018-6-23
Turkey
S-e-ven Posted at 2018-6-23 06:42
no,gimbal is ok now.
2018-6-23
