beatles
Flight distance : 113353 ft
Guys, This is the reply I got from the service center. Sounds a bit $$$ to me. Should i just have them do the firmware updates and forget the rest then buy my own camera? The right arm isn't very bad at all.We have finished diagnosing your Inspire 1 and this is what we found. Upon examination we found damage to Right arm, 3 landing gears needs to be replaced, aircraft needs firmware upgrade, and camera/gimbal system is damaged. We tested the gimbal and noticed there was delay in the motor as well as stability. Unfortunately we don't repair the gimbals/camera we can only replace it with a newer one. We can offer you a new X3 for $610. The estimated cost for the repair on your aircraft is $734 without the camera/gimbal. |
