DJI Assistant 2 1.2.4 Exe file is not running on Windows 10 laptop
12Next >
14706 63 2018-6-24
ManojExplorer
Tanzania
I have recently purchased Mavic Air Fly More Combo. I downloaded DJI Assistant 2 1.2.4, and was trying to install it on my laptop with Windows 10. But it simply doesn't start to install. Tried running the program as Administrator but same result.
2018-6-24
DJI Wanda
Hello there. We apologize if you're having some issues right now. Try to use this link: https://dl.djicdn.com/downloads/ ... sistant+2+1.2.4.zip
2018-6-24
FanOfFlight
Flight distance : 1983760 ft
I had this issue with some non DJI software.  What I did to fix it was after the download, I right clicked on the folder and there was a "Blocked" check box in the bottom right of the properties folder.  When I unblocked BEFORE unzipping the file, the application worked.
Windows 10 has some security stuff going on, and it can block/will block some programs from running to protect your system if the author of that program didn't properly do something to the file.
Hopefully this helps you.
2018-6-24
Punchbuggy
Flight distance : 483166 ft
This is specific to your laptop, as the app Does install. I'd suggest you try to install it after having temporarily disabled your anti-virus software - it may be blocking installation by default.
2018-6-24
DJI Tony
Please keep us posted in any case that the issue will occur. Thank you.
2018-6-25
grobleben
Flight distance : 18780 ft
The Assistant 2 latest version installed properly. But it isn`t detecting the device. I installed on a desctop too, but the same result.SW is windows 10 latest version.
2018-7-8
fansb67326a3
This is the message I get after selecting DJI=ASSISTANT=2=1.2.4.EXE RUN AS ADMINISTRATOR.  I NEED HELP HERE, WHAT IS GOING ON HERE.
2019-3-12
Keule
Flight distance : 3733015 ft
DJI's code signing certificate has been revoked. Hence the UAC error ...
2019-3-12
larryc43230
Flight distance : 664534 ft
Keule Posted at 3-12 21:36
[view_image]
I've had DJI Assistant 2 (latest version) running for months, but now every time I try to run it Windows blocks execution with the message in the post above. My PC is running Windows 10 with the latest system updates.
From what I can see, DJI will have to fix the Code Signing Certificate.
I'm aware that I can force it to run by lowering the security shields on my PC, but that's not an option in my case. I prefer to maintain a safe machine and just not run DJI Assistant 2 until this issue is resolved.
Larry
2019-3-13
gaardhund
Flight distance : 42231 ft
Denmark
I get the same message.
2019-3-13
Trailkill
Flight distance : 317031 ft
Same problem here. Come DJI lets get with it and get this fixed. You guys aren't looking too good. You're failing in a lot of areas.
TK
2019-3-13
Hurley1718
Flight distance : 549295 ft
I had to re-download the DJI Assistant 2 software from the DJI download page and ran into problem when installing it onto Windows 10 Enterprise Version 1803.
When launching the installer it fails and gives the error message "this app has been blocked for your protection".
Here is how to bypass that error.
Click on the Start Window and typ CMD to pull up the Command Window. Then right click the CMD icon and select Run as Administrator.
When you are in the Command Window point to the location of your .exe file and hit enter. Example: C:\Users\Profile Name\Downloads\DJI+Assistant+2+1.2.4.exe
It should then launch the installer and walk you through the process. Hope this helps some people.
2019-3-13
Hurley1718
Trailkill Posted at 3-13 07:51
TK
2019-3-13
Hurley1718
larryc43230 Posted at 3-13 02:51
2019-3-13
Hurley1718
gaardhund Posted at 3-13 06:15
2019-3-13
Hurley1718
2019-3-13
Trailkill
Hurley1718 Posted at 3-13 08:03
Thanks Hurley I got to install and ran once but now it won't run again. I'm not going through that everytime I need to run DJI assistant.
TK
2019-3-13
Hurley1718
Trailkill Posted at 3-13 09:07
TK
That's strange that it doesn't let you run it multiple times. I'll do some more digging around.
2019-3-13
kovat53
Flight distance : 324521 ft
Hungary
Agree with you
2019-3-13
HH1
Flight distance : 73114 ft
Got red warning notice, can NOT run assistant on W-10 desk top computer.  ???  Hope answer from dji is forthcoming.
2019-3-13
fans33ec820b
Flight distance : 896686 ft
Norway
Same problem. Will not install
2019-3-13
kovat53
Hungary
HH1 Posted at 3-13 13:16
It's a must.
2019-3-14
djiuser_ngHCPmzQN6nn
Costa Rica
I just bought a Mavic Air fly more combo and I'm having exactly this same issue. It also doesn't let me update the aircraft firmware using the DJI Go 4 app... Is so frustrating.
2019-3-15
djiuser_A9C4zAdfsrhx
Hurley1718 Posted at 3-13 08:01
This fix does work!  Thank you for the guidance.  Too bad DJI can't fix this problem.
2019-3-19
Scott.Collinson
Flight distance : 1073 ft
Hurley1718 Posted at 3-13 08:06
I don't understand "point", please explain further.
2019-3-19
Scott.Collinson
I don't understand what you mean by "point" in your explanation could you please elaborate.
2019-3-19
djiuser_kr5VilCM64tK
Flight distance : 1598750 ft
Hi Hurley
  I opened cmd in admin mode as you suggested.
It says c:\WINDOWS\system32> then a cursor.
I copied and pasted the file location from properties. It looked almost exactly like your example except "user name" was MY user name.
  I Typed .exe directly after and hit Enter.
Is this what you mean by "point to"?
I got a message
    "Is not recognized as an internal or external command, operable program or batch file."
  What am I doing wrong?
2019-3-19
Hurley1718
djiuser_kr5VilCM64tK Posted at 3-19 13:49
Hi Hurley
in the command window do a CD\ to get to the root level of your c drive. Then type int he path to the installer.
2019-3-19
Hurley1718
Scott.Collinson Posted at 3-19 12:57
By "point to" I mean type in the path of the installer into the command window. Make sure to do a cd\ to get to the root level of C: Drive
2019-3-19
QuadFunAus
Flight distance : 38835 ft
Like many others, I am getting the same message.  My MA is asking to connect to DJI Assistant 2 for calibration of sensors, so until DJI fix this issue I am stuck.  I wonder if DJI are willing to repair MA if I crash due to a sensor problem, given they are currently not providing a platform to fix the error.
2019-3-19
QuadFunAus Posted at 3-19 16:30
Hi QuadFunAus, we have found the cause of the issue and are working on it. You can install or run DJI Assistant 2 software using a computer with Windows 7/8 or Mac temporarily.
Currently, the DJI Assistant 2 for other products such as Phantom, Matrice has been updated, the version is v2.0.7, the new update of DJI Assistant 2/DJI Assistant 2 for Mavic is under the final test and will be released soon, please wait patiently, thank you.
2019-3-20
fans33ec820b Posted at 3-13 14:55
Hi there, we have found the cause of the issue and are working on it. You can install or run DJI Assistant 2 software using a computer with Windows 7/8 or Mac temporarily.
2019-3-20
djiuser_ngHCPmzQN6nn Posted at 3-15 03:11
Currently, the DJI Assistant 2 for other products such as Phantom, Matrice has been updated, the version is v2.0.7. The update of DJI Assistant 2/DJI Assistant 2 for Mavic is under the final test and will be released soon, please wait patiently, thank you.
2019-3-20
djiuser_A9C4zAdfsrhx Posted at 3-19 09:27
2019-3-20
Questttt
Cyprus
today is 21 3 2019 and i paid lot of money for Zoom 2 and cant install the file, same message come, and the solution given doesn't work also .. this is absurd
2019-3-21
Keule
Questttt Posted at 3-21 11:03
Be sure to access the English version of DJI's website and download Assistant 2 for Mavic 2.0.7
DJI is not able for whatever reason to provide all localized, latest versions of their software.
2019-3-21
Punchbuggy
Keule Posted at 3-21 11:19
Yeah, you're right, Keule.
I use a VPN so I keep being forced to different language versions of the DJI site - some of which don't offer the v2.0.7 version. There's a direct link provided in one of the other threads which will get people around that.
2019-3-21
QuadFunAus
DJI Mindy Posted at 3-20 01:30
Thanks for reply Mindy, I only have windows 10 devices so I can't run on anything else.  Hopefully, DJI can come up with a fix sooner rather than later!
Cheers
2019-3-21
Punchbuggy
QuadFunAus Posted at 3-21 20:19
Cheers
Quad, did you read the messages just prior to yours?
2019-3-21
Tomcatuk
Flight distance : 28743 ft
Why does the admin have to reply to each person with the same message what a waste of space.....
2019-3-22
12Next >
