Where can I find older versions of DJI Assistant 2
12Next >
41027 52 2018-6-24
kchevy
I am having a problem getting current the version of DJI Assistant 2 to recognize my RC for my Mavic Air. I read in another thread that people have had success installing an old version and then updating to current version. Can somone tell me where I might find older versions of DJI Assistant 2? Thanks for the help.
2018-6-24
DJI Wanda
Hello there. We apologize for the inconvenience that you're having right now. Have you tried to restart the computer first before launching the app? Did you try to reinstall the app?
2018-6-24
kchevy
DJI Wanda Posted at 2018-6-24 04:28
Yes I have tried both suggestions. There is mention in another post that there is a special driver that has worked for some people. I also have seen that installing previous versions of DJI Assistant 2 and then updating to the current version has worked.
2018-6-24
DJI Wanda
kchevy Posted at 2018-6-24 04:38
Try this:
Windows: https://dl.djicdn.com/downloads/ ... ant+2+1.2.2.845.exe
Mac: https://dl.djicdn.com/downloads/ ... ant+2+1.2.2.845.pkg
2018-6-24
kchevy
DJI Wanda Posted at 2018-6-24 04:44
Try this:
Windows: https://dl.djicdn.com/downloads/dji_assistant/20180224/DJI+Assistant+2+1.2.2.845.exe
Thank you Wanda, When I click on the link (Windows) it said access denied? Am I doing something wrong?
2018-6-24
DJI Wanda
kchevy Posted at 2018-6-24 04:54
No problem. You can try to use a different browser and click the link itself. Once you click the link, it will automatically start the download process.
2018-6-24
kchevy
DJI Wanda Posted at 2018-6-24 05:23
I have tried IE, Edge & Firefox. All tell me that I not authorized?
2018-6-24
DJI Wanda
kchevy Posted at 2018-6-24 07:08
How about Chrome?
2018-6-24
kchevy
<?xml version="1.0" encoding="ISO-8859-1"?>
This is what happens
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>94A302B9CE677027</RequestId>
<HostId>Sd0s5/bn8op3nRrzN4z1AnXXNq5kbmCdZJ3Rwd6VY5oa65vblk8t99eB1UiN9TnCQFDT66q1AkU=</HostId>
</Error>
2018-6-24
Rivi
Flight distance : 74521 ft
United Arab Emirates
I tried it as well.  That hyperlink doesn't look right.  Its a https message with three dots on part of the URL.
2018-6-24
G_Sig
Flight distance : 9109311 ft
Iceland
Sorry Dji Wanda but the link you posted is not working.
2018-6-24
Wachtberger
Flight distance : 261509 ft
Here you can find a driver package from DJI that has solved the problem for me and many others: https://drive.google.com/file/d/ ... FE/view?usp=sharing
It is important to have the aircraft connected and switched on while installing the drivers!
And here I have uploaded an old version (1.1.6) of DJI Assistant: https://drive.google.com/drive/f ... 1spF8fXu9c7D8Wtxr7v
2018-6-24
sky6105
Flight distance : 345653 ft
You can also look here I had the same problem.
This worked for me.
Old Version
2018-6-24
HedgeTrimmer
Try this:
Hello DJI Wanda:
   Neither link works for me.
   Can you please post working links for both Windows & MAC (OS X) to earlier revisons of Assistant-2.
Thanks.
2018-6-24
kchevy
Wachtberger Posted at 2018-6-24 08:12
Here you can find a driver package from DJI that has solved the problem for me and many others: https://drive.google.com/file/d/0B4jKLmmRYhQaX3pYOXJRWkpzSFE/view?usp=sharing
Thank you all. Wachtberger, I found you posted that driver in another thread. I already tried that without success. There was a driver that DJI Thor sent to several people that worked. I sent Thor a pm for that driver but has not responded yet.
I will try the older version of DJI Assistant 2 and see if that works and will post my results.
2018-6-24
DJI Wanda
G_Sig Posted at 2018-6-24 08:08
I apologize for the inconvenience. You can refer to the link that was provided by Wachtberger's or sky6105's answer if the link I provided didn't work.
2018-6-24
G_Sig
Iceland
DJI Wanda Posted at 2018-6-24 09:08
Thanks for the replay.
I don't need this link as I'm running 1.1.6 and will stay there.
Was just pointing out that the links don't work.
Had this driver problem when first running Assistant but everything have worked
last year as suspected.
2018-6-24
kchevy
kchevy Posted at 2018-6-24 09:01
I installed DJI Assistant 2 version 1.1.6 without success. Same problem-the RC will not connect. Does anyone who had this problem have the driver that DJI Thor supplied?
2018-6-24
Wachtberger
You are welcome. The driver link that I have posted came from DJI Thor a few months ago. Maybe there is a newer version available now that I don't know yet.
2018-6-24
HedgeTrimmer
Hello DJI Wanda:
   The links for MAC (OS X) Assistant-2 previous versions are all dead.
Please escalate this matter with DJI Corporate, being current version of Assistant-2, and preceding version of Assistant-2 will not access either FlightLogs or Blackbox data on Mavic Pro P.
Thanks in Advance
2018-6-24
djiuser_I1N6CK9QrV7g
Flight distance : 4517064 ft
Mexico
Is there a driver for win7 available?
2018-6-24
sky6105
When I had that problem I uninstalled Assistant-2 from the computer installed version 107 exe.
Then I updated to the new version over top of that and I was able to reconnect to the RC.
2018-6-24
DJI Wanda
HedgeTrimmer Posted at 2018-6-24 10:14
Hello DJI Wanda:
I see. Thank you for reaching this out. I'll raise this up to our management. Thank you for your patience.
2018-6-25
DJI Diana
Flight distance : 2408 ft
djiuser_I1N6CK9QrV7g Posted at 2018-6-24 10:52
Hi there, sorry for the late response, I have shared a link to download the driver via PM, please go to check it and follow the steps to install it. Please keep us in updated. Thanks.
2018-6-26
DJI Diana
kchevy Posted at 2018-6-24 09:57
Hi kchevy, sorry for the inconvenience. I have shared a link to download the driver via PM, please go to check it and see if it helps or not. Any further issue, please feel free to let us know. Thank you in advance.
2018-6-26
A CW
Flight distance : 13864580 ft
sky6105 Posted at 2018-6-24 11:27
That worked for me too
2018-6-26
kchevy
DJI Diana Posted at 2018-6-26 00:28
DJI Diana. Thank you so much, it worked. I am very happy now :-)
I have to say though that I am disappointed with online & phone support from DJI. First I called support and the person that I spoke to confirmed that the software was current for the RC. She then tried to tell me everything was ok and there was no update. When I tried to tell her that the RC still did not connect to the PC, she told me to take a video of the controller attempting to connect to Assistant 2 and send it in to online support. She said I should hear back in a few weeks? I just bought my MA and haven't even flown it yet. I then went to online support and got basically the same response. It wasn't until I showed the person several threads in the forum indicating that there were numerous people with the same issue that he took my information and set up a case. This is very disappointing support for a $1000 dollar purchase.
I don't understand why the 2 levels of support that I contacted could not have given me the fix like you did. I really hope this is not what is in store for me in the future.
2018-6-26
Latvia
Worked for me
Big thanks DJI Diana
2018-6-27
Junaid_Xaidi
Flight distance : 150463 ft
Ghana
Hello Can you please share the driver with me also. My RC wont connect with Mavic Air and  DJI assistant-2
2018-9-5
Carlross
Flight distance : 8448 ft
Can any body send me solution for mavic air rc not connecting to pc please
2018-9-23
Qi Yuan
Malaysia
please help me out, i cant connect to rc as well!!
2018-9-23
Sis
Flight distance : 29219 ft
Me too, the links for DJI Assistant 2 1.0.7  that I found on this forum doesn`t work.
2018-9-24
The_Tiger
Any update? Any link for the driver or the 1.0.7 version of assistant 2?
2018-10-2
Imad75
hi guys, i have the same problem recognizing my RC and Mavic Pro
any updates or links available ?
2018-10-15
BobDoLe
Flight distance : 763094 ft
THIS IS PRETTY GOSHDARNTOOTIN RICOCKULOUS....
can you pm me the link to the previous version 1.07
it seems DJI probably had all links killed off
2018-10-27
Tomcatuk
Flight distance : 28743 ft
Sweden
That's exactly what I did and since then works perfectly
2018-10-28
BobDoLe
Tomcatuk Posted at 2018-10-28 00:14
really... can you upload your 1.07 installer anywhere and link it here?
once i get my hands on it, i'll make sure it stays uploaded somewhere
2018-10-28
Tomcatuk
BobDoLe Posted at 2018-10-28 17:48
Unfortunately no longer have it, and seems even 'official' support on here are giving out dead links...
2018-10-29
BobDoLe
GUYS.. SOLUTiON - I HAVE IT
go get the dji flight simulator (trial version).
install it. you may not need to actually run it after it installs - in my case it downloaded 1.5gigs and failed to unpack a few times.
in your C:\Program Files (x86)\DJI Flight Simulator directory, you'll have a "dji_usb_5512_64_108.exe"
run THAT and you get the remote controller driver working.
2018-11-4
T369
Flight distance : 7031 ft
BobDoLe Posted at 11-4 06:19
Thanks so much! Been trying to find the old DJI assistant that everyone keeps mentioning, but downloading the simulator and running the USB executable did the trick and is much simpler.
2018-12-10
12Next >
