G Davidson
Flight distance : 263465 ft
Mag8 Posted at 2018-6-27 03:59
Great photos! Would you mind sharing your process from start to finish? I can never get my 360 photos to this kind of quality.
Thank you - glad you like them!
Sadly the process is quite involved and changes depending on what difficulties I run into but in all cases the panorama consists of two separate panos, one of the ground from the P4 and the other shot from a D810 with fisheye on the ground of the sky. The two finished panoramas are then brought together. I'm using Kolor AutoPano Giga for the stitching (that can be a black art in itself, even after the 12 or so years I've been using it!)
Exposure is decided on a shot by shot basis whilst manually shooting the pano in the air. Gets more difficult in low sun where I've to take account of avoiding overlapping lens flare between shots and try get the stitcher eliminate them. The images are then pre-processed for exposure, sharpness, hot pixel removal before stitching.
I put in waaay more effort than some of the scenes justify but I like to try my best
Sorry not to have been able to give you a step by step guide. One more thing I should mention is that I'm using a fairly high-end workstation (Dual Xeon 12core 48GB RAM) for this work and it taxes the machine somewhat - it turns into a space heater when rendering! I've had it a few years now so it may be that newer mainstream machines are capable of similar performance. AutoPano Giga was the reason I had to get a decent machine. |
