I LOST THE WIFI PASSWORD SPARK / PERDI A SENHA WIFI SPARK
10250 6 2018-6-26
fans31f8341e
I TRANSFERRED THE SPARK CENTRAL BOARD AND DID NOT SEE THE WIFI PASSWORD.  HOW TO RECURRATE?
TROQUEI A PLACA CENTRAL RECENTEMENTE DO SPARK E NÃO VEIO A SENHA DO WIFI.  COMO RECURAR ?
2018-6-26
BrilhasMuito
Flight distance : 3745554 ft
Brazil
Tem na caixinha de isopor que vem o spark. Do lado de fora em um adesivo.
2018-6-26
fans31f8341e
BrilhasMuito Posted at 2018-6-26 12:49
Amigo, como falei no post, troquei a placa do spark quem me vendeu não tem a senha.
2018-6-26
BrilhasMuito
Brazil
fans31f8341e Posted at 2018-6-26 12:52
PQP, verdade, viajei!
2018-6-26
DJI Tony
Hi, I would like to clarify if you're trying to retrieve the Wi-Fi password of your aircraft? If yes, please follow the video below.
2018-6-26
fans31f8341e
DJI Tony Posted at 2018-6-26 13:23
https://www.youtube.com/watch?v=MwAVJSbO8Ek
Friend, my mother board burned I traded for another board, and the seller does not have that password, and I do not have the new board box
2018-6-26
DJI Tony
fans31f8341e Posted at 2018-6-26 13:40
Does your phone detect the Wi-Fi network of your spark? Have you tried to reset it? Actually, we are not recommending fixing your drone on your end due to you might avoid the warranty, however, you might try as well to download the DJI Assistant 2 then look for Wi-Fi setting and check if could be able to pull up the Wi-Fi password of your aircraft. Please see the image below.
2018-6-26
