Spark on boat?
570 2 2018-6-27
Iron Maiden Fan
Flight distance : 23642 ft
hello there!!!!
any you folks use your drone on or from your boat?
i would love to start fliming out outings like tubing, wakeboarding, and just having goodtime.
any tips? dos and donts?
share your vidoes!!!!!
Up the Irons!!
marty
2018-6-27
DJI Paladin
Flight distance : 318 ft
Hi there, we don't suggest flying your spark on a low altitude over the water surface. I think
the problem is that it greatly reduces your emergency landing area. Please make sure to be careful with battery levels an check the drone's status before taking off.
2018-6-27
Gunship9
Brush up on your U-boat commanding skills as under the water is where boat based drones often operate.  Be sure you have top notch piloting skills over land before flying over water.  Watch out for the drone to try to RTH to the empty spot of water the launch boat started out at. The drone is programmed that the home point is the best place to land when it really isn't for water flights.
2018-6-27
