New GL300K Firmware Released
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2018.06.28
  • Firmware: V 01.00.01.00
What’s New?
  • Fixed an issue that caused the screen to become blurry.
  • Improved system stability and user experience.
Notes:
  • Both the aircraft and remote controller firmware must be upgraded.
  • If the firmware update fails, restart the aircraft, remote controller, and DJI GO 4, then try updating again.
2018-6-28
KedDK
Flight distance : 1133038 ft
Denmark
"Improved system stability and user experience."
The first part sounds nice but the second usually would end up being the opposite.
Best luck 2.0+ users.
And for the info, if you have trouble with the login in after the update you might just need to re-configure your network settings, found in the settings after dragging down from the top of the display.
2018-6-28
Rivi
Flight distance : 74521 ft
United Arab Emirates
Did the update. No issues so far.
2018-6-28
Rivi
The Flight data update seems to have changed.  Feels faster.
2018-6-28
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2018-6-28
fans342d3f5e
Just got a 2nd hand P4 in as new condition and the airframe is failing all update attempts (RC updated fine) have been trying via Assistant 2 and PC wont even reset to factory default, what am I missing here.. Batteries are at 100%
2018-6-29
KedDK
Denmark
fans342d3f5e Posted at 2018-6-29 00:06
You're missing that this thread is for the P4Pro V2.0 plus controller not P4 issues.
Search for a existing thread that match the error you get or start a new thread and select the Phantom 4 section when making it.
2018-6-29
A CW
Flight distance : 13838848 ft
Good illustration
2018-7-1
Kenneth R.
Flight distance : 201850 ft
Bulgaria
Why is this in the Mavic forum?
2018-7-1
KedDK
Denmark
Kenneth R. Posted at 2018-7-1 11:36
Just as a sort of revenge for all the Mavic announcements that has been flooded the Phantom section.
No they are global for some time those release threads, you'll see it in all sections right now.
2018-7-2
DJI Susan
Sorry to read the troubles. Could you read the current aircraft firmware when connecting with DJI Assistant 2? If yes, it is recommended to refresh the firmware and see whether it works.
2018-7-2
KedDK
Denmark
Why has this already been taken off as sticky in the overall list for the Phantom?
It is more relevant than several of the other threads that keep hanging in there and not even shown up in the P4P listing makes it hard to find!
2018-7-5
Jenz Hoofs
My downloaded zip does not contain a .bin file but a lot of maps mean directory contains: META-INF and a system map. what should i do with this ?
2020-7-13
