Mark The Droner
Flight distance : 2917 ft
It's a shame when the DJI stick antennas break off because DJI is really good at everything they do, and that includes antennas. Ideally, if you wanted to replace that stick antenna with another stick antenna, you would replace that antenna with another DJI antenna just like it. And I know they're around because lots of people have done mods and managed to remove the OEM DJI antenna without damaging it too badly at the base, although it's tricky to say the least. But if you replace the DJI stick antenna with some other stick antenna such as Argtek, it almost certainly won't perform as well. OTOH, if you replace the stick antenna with a panel antenna such as Argtek, which is more directional instead of omni, you potentially could get more range. However, if I was going to go to all the trouble of doing an antenna mod, I'd replace it with the best antenna I could find, and that would be an ITELITE because that's what the long distance guys like. Remove the guess work and choose to use an antenna that the experts choose to use. But otherwise, if you never had range problems to start with, you may be satisfied with the Argtek whether you go stick or panel.
Note that the Argtek is painfully vacant from this list of antennas used by P4 range leaders: https://phantompilots.com/thread ... -leaderboard.72554/
Also note that the list is not up to date because, apparently, the OP can't keep up with it. I have repeatedly asked him in emails to update it and he has promised in emails to update it "today" but the day ends and nothing happens and more weeks go by and still nothing happens.
Good luck.
