DMX_MT
Malta
Bavaria,
Power on the Spark - Then Press
Try these Commands -
3 Seconds - 1 Beep - Connect Remote
6 Seconds - 2 Beeps - Connect Phone and use Virtual Joysticks
9 Seconds - 3 Beeps - Reset Wifi
You need to do the 3 Seconds Procedure to Switch to the Remote Controller connecting to Spark.
Did you try that at first place ?
Simple sum-up
1. Turn on remote & Spark.
2. Press button on Spark's battery until you hear a beep (around 3 seconds). The LEDs under the front engines should be red and blinking.
3. Press and hold the pause, Fn, and Control button on the remote. It will start beeping. When it manages to pair itself to the Spark, the LEDs under the front engines will be green (the small LED on the remote will also be green).
