Samsung Galaxy Tab S2
8163 21 2018-6-28
djiuser_bBVoTTNbj8Wa
I've been using an old Google Nexus 7 with my P4P. I got a Samsung Galaxy Tab S2 and I've only been able to get it to connect to the P4P controller twice, out of about 100 attempts. I've been doing it with WiFi disabled on the Samsung Galaxy Tab S2.
II got Litchi and tried it and I have the exact same problem. I've only been able to get Litchi to communicate with the Samsung Galaxy Tab S2 once.
Both apps work fine with my old Google Nexus 7. Does anyone know what is causing the problem with my Samsung Galaxy Tab S2?
2018-6-28
charlesP4P
Flight distance : 130230 ft
I went through exactly the same thing about a year ago - Nexus 7 worked fine all the time but sometimes a little slow, Galaxy Tab S2 connected now and again,  then one flight totally disconnected.  I searched high and low but never found a solution, so I bought an Ipad Mini 4 which always works
A bonus - I found that the iPad is in general a much better tablet all round and is now my tablet of choice. It has a larger display than the Nexus 7 which is nice. The only downside is that it does not have GPS (the non cellular version that is)
2018-6-29
Air/America
This forums thread > Tab S2 to P3 Pro Connection Problem
2018-6-29
DJI Gamora
Hi, thanks for reaching DJI Forum. We do apologize if you are having issues with your connection with your mobile device. Below is the list of the compatible devices. Thank you.
2018-6-29
Air/America Posted at 2018-6-29 03:31
Thank you! That works! Only problem is that I have to do it every time I start the controller or the tablet.
2018-6-29
Bashy
Flight distance : 2354357 ft
djiuser_bBVoTTNbj8Wa Posted at 2018-6-29 11:22
Root the device and put on Android 6, it will be good from then
2018-6-29
Bashy Posted at 2018-6-29 21:16
Thank you for the reply. Downgrade the operating system? I've never done anything like that.
I could return the S2 and get something else. Any recommendations other than a iPad?
2018-6-30
Bashy
S3 lol Yeah, it can be a bit daunting doing it if you've never done it before, shame....
2018-6-30
Air/America
That sounds like a good idea. Is there an available tutorial as how to root the S2 "down" to the Android 6? I was thinking that my S2 worked great with the DJI app until the S2 upgraded to Android 7.
2018-6-30
Anyone know if the Tab S3 would work?
My Tab S2 overheated after a very short time in 90 degree weather today and Litchi shut down while I was flying. Fortunately I was within line of sight ans was able to fly back safely.
2018-6-30
Bashy
Air/America Posted at 2018-6-30 04:26
Try here
2018-6-30
Bashy
djiuser_bBVoTTNbj8Wa Posted at 2018-6-30 17:52
Not had mine over heat but then i have not flown in 90º heat before, not over 80º for me
2018-6-30
Air/America
Bashy Posted at 2018-6-30 19:55
Try here
https://www.youtube.com/watch?v=ypMcc6FQ8iI
Thank you for your reply. I will have to take a look into the suggested down grade technique.
2018-7-1
Bashy
Just note that if you use internet banking apps then they may not work on a rooted device!!!
2018-7-1
PIXI_Ph
Flight distance : 103123 ft
Hungary
Hi,
Here is the solution:
Entering the service mode, you need to change the USB mode.
The following must be done.
You will need to enter a calculator and enter it (+30012012732+ and then press + and then enter the code input interface, then type * # 0808 # to enter the USB configuration interface, instead of the original MTP instead of the RMNET + DM + MODEM must be selected and then OK. If this is the case, then if you connect the DJI line, you have to work immediately on the connection.
2018-11-9
ATJ
Flight distance : 17736 ft
PIXI_Ph Posted at 11-9 01:53
Hi,
Make sure you RC is turned on and plugged into your S2. The go into Developer Options >USB and choose MTP
2018-11-9
Edward J Smith
Flight distance : 1852408 ft
I have come up with a work around that will connect every time without issue. This has also been tested with the latest operating system updates without issue as well.
The root of the problem is either DJI GO4 or the controller is not handling the USB connect protocol correctly.
Step One
Place your Tablet in Developers Mode.
Follow the instructions here>
http://visihow.com/Enable_the_De ... msung_Galaxy_Tab_S2
Step Two
Once in developers mode, open settings, scroll down to the bottom of the left hand menu and select Developers Options.
Once in Developers Options, scroll down to USB configuration. Change USB settings from MTP to RNDIS
Your P4P should now connect – Every time.
Notes
The Tablet wont remember your change in settings. It will revert to back MTP. So you must make this change each time you connect.
2018-11-10
ATJ
Edward J Smith Posted at 11-10 05:31
What version S2 do you have:
Versions (2016): T813N (Wi-Fi); T819N (3G/LTE)
Versions (2015): T810 (Wi-Fi); T815 (3G/LTE)
Also what OS are you running?
2018-11-10
Edward J Smith
ATJ Posted at 11-10 06:04
I have the SMT813N WIFI I DON'T REMEMBER OFF THE TOP OF MY HEAD WHAT 0S VER I AM RUNNING.
2018-11-21
ATJ
Edward J Smith Posted at 11-21 13:45
OS
Android 5.0.2 (Lollipop), upgradable to 6.0.1 (Marshmallow) - T810, T815
Android 6.0.1 (Marshmallow), upgradable to 7.0 (Nougat) - T813N, T819N
2018-11-21
Edward J Smith
ATJ Posted at 11-21 13:50
OS
I believe I'm running nougat
2018-11-21
Teddonald
Flight distance : 108812 ft
I have found this solution, maybe it could help to connect to a Galaxy tab S2
https://youtu.be/pxHcoCTx1mw
2019-5-4
