Caching a map before flight
564 7 2018-6-28
Mirek6
Flight distance : 594882 ft
Hi,
In order to display flight map during Spark's flight one needs to have working data connection to Internet (e.g. via LTE).
However, if I am in the middle of nowhere with no cellular range, the map will not show on DJI GO when I fly unless I cache it first when I am still within cellular or Wifi range.
I know that apps for higher end drones do have capability of caching map. I also have heard people claiming that it is possible with DJI GO app with Spark.
However, I cannot find such option in my DJI GO.
How do you cache a map in DJI GO for Spark?
Mirek
2018-6-28
JimboHUN
Flight distance : 37156 ft
Hi Mirek,
Om the main page in the drop down menu you can select Offline maps and download some areas while you are in wifi range.
This works in 4.2.12 and 20 on Android, I cannot comment for other versions.
Cheers.
2018-6-28
Terp1234
Flight distance : 50906 ft
Indeed it's there in Android, but not available for iOS. What are you using Mirek?
2018-6-28
msinger
Flight distance : 183694 ft
You can find instructions for caching the map data in DJI GO here:
http://www.phantompilots.com/thr ... 97154/#post-1002870
2018-6-29
Mirek6
JimboHUN Posted at 2018-6-28 20:56
Hi Mirek,
Ahhh - yes. I did not notice that.
I was looking for this in within general setting in Camera View.
Many thanks - I will test it today.
Mirek
2018-6-29
Mirek6
msinger Posted at 2018-6-29 01:56
http://www.phantompilots.com/threads/possible-to-use-usb-cable.97154/#post-1002870
msinger,
The menu shown in the phantom link you provided does not exist in the Android version DJI GO app for Spark. Under General Settings there is no "Cash map in the Background" option. I use androi. Perhaps it does show in iOS - I don't know.
However, JumboHUN gave an option which does exist.
Mirek
2018-6-29
Mirek6
Terp1234 Posted at 2018-6-28 21:32
I use Android and found menu which JimboHUN suggested. Thanks!
Mirek
2018-6-29
msinger
Mirek6 Posted at 2018-6-29 04:31
msinger,
Right. Per the post I linked above:
"If that setting is not visible in DJI GO, then it's automatically enabled by default."
2018-6-29
