Hello, need Quick help.
I cant record movies to SD card, no matter what i do, i Press record button and nothing happens. 2 days ago i had no problem recording 1080p 60fps and today i cant do anything.
Please help, i got class 10 Kingston 64gb card.
I think mavic has killed my sd card, i cant get rid of the files on it anymore, neither format or just delete, cant write on it aswell. Switching sd card obviously fixed the issue but im afraid if MA wont kill the new one .
Have the same problem. Drone says sd card too slow. As I use Samsung evo class 10 U1. It will not allow me to select sd card. What I did was fill up the onboard storage then it asked if I wanted to save to sd card click yes and problem went away as long as you don’t select 4K recording (it still says slow sd card). I have since emptied the onboard storage. And set recording to 1080p. Till I can afford to get a new sd card.
DJI Stephen Posted at 2018-6-29 07:54
Hi. I am sorry that you are having issues with the SD card on your DJI Mavic Air. Have you tried to a different SD card on your Drone to record?
I tried new card and it works fine so far, some random 32gb Kingston but enough for 1080p 60fps, i will update if it will die aswell.
