KedDK
Flight distance : 1133038 ft
Denmark
If you only get 200m range something is not right.
First thin to check is that both controller and aircraft are on a matching firmware level, latest is 1.4.1.0/1.5.600. Also you app need to be a version from about same release time as your current firmware version. Put your device in flight mode.
If still you have this bad range you should consider returning it for a replace. |
