infrared camera Phantom
fans63974ffd
Flight distance : 629800 ft
Has anyone changed out the camera that comes on the P4 or P3?    I have some business opportunities that could call for use of infrared cameras.  Im working if I can make that happen with a P3 or 4.  Or do I need to look at investing in an Inspire?
Thanks!
2018-6-29
ALABAMA
Flight distance : 10442687 ft
No Phantoms have this capability.
2018-6-29
DJI Gamora
Hi thanks for reaching DJI Forum, sad to say there is non yet of a feature that caters changing camera's from the P4 or P3 series.
2018-6-29
fans63974ffd
So is the inspire the drone I need to look at?  Which Camera?
2018-6-29
Nigel_
Flight distance : 388642 ft
What sort of infra red do you want?
https://www.mapir.camera/collect ... single-camera-mount
2018-6-29
fans63974ffd
Nigel_ Posted at 2018-6-29 06:40
https://www.mapir.camera/collections/mounts/products/dji-phantom-4-mapir-survey-3-2-1-tilting-single-camera-mount
interesting.  Have you tested one of these?
2018-6-29
Nigel_
fans63974ffd Posted at 2018-6-29 07:11
I know the Survey2 and Survey3 cameras because they are rebadged Gitup action cameras with customised lenses and firmware, the Survey3 is a very nice camera, however I haven't used them with IR lenses.  Although I have used the standard 2 with no IR filter which can produce some interesting photos, probably not what you want, but you haven't said what you want yet...
2018-6-29
fans63974ffd
Nigel_ Posted at 2018-6-29 07:24
[view_image]
looking to detect moisture on commercial facilities for a roofing contractor
2018-6-29
Nigel_
fans63974ffd Posted at 2018-6-29 07:48
Interesting use, but I'm not sure what cameras are capable of doing this.  The difference between a damp roof and a dry roof must be quite small in the near infra red, how does it work?
Maybe two of those Mapir cameras side by side with IR filters for different bands would show a difference between the two cameras that would indicate dampness?  Seems unlikely it would be detectable.  Maybe more detectable would be a thermal difference with a damp roof taking longer to warm up in the morning sun, but you need a different type of camera for far infra-red thermal imaging: https://dronexpert.nl/p/5956/
2018-6-29
KedDK
Flight distance : 1133038 ft
Denmark
Not sure it would suit your needs but if you do a search for FLIR you will find some previous threads here also with links for some phantom mounts.
Edit: Just as Nigel linked to above.
2018-6-30
陈志鸿
Can go here to see, their accessories, service personnel are very professional to solve my many problems ,quanhom
2019-4-16
