MartyTravelsTheWorld
Flight distance : 394173 ft
Indonesia
Don't want to be rude, but how can you buy a fake SD card nowadays? I always buy the same manufacturer since years via different channels and I didn't have a single non-performer, yet.
I even bought 2 in hongkong from a street vendor kind of place which are decent.
If you are in the western world and you do what you do professional, you can't have a fake SD card unless you are stupid.
Since this is probably not the case your SD card is broken or your Spark is broken.
There is one more possibility: If you have a Sandisk they have build in security measures to prevent data loss if something goes wrong with the card and it will switch itself into write protection mode. Any device will write to the card (at least it appears that way) but it doesn't. If this is the case you have to send the SD card to the manufacturer for a replace.
But since I don't know what kind of SD card you have it's just speculation. But loosing a client through such an error is embarrassing and absolutely f*cked up because you just don't know what happened.
On the other hand, not DJI fault, just very bad luck. |
