Hi I would be very intrested to hear how u got on with Splashot... ?
I did not get it to work at all with videos. iPhone screen mirror did work, but very slow.
I logged a call with Splashot and this is the answer i got.
HiChris,
Sorry,the lag/latency is directly related to the AP on the remote control. Airplay does not allow you to change the resolution setting so with aniPhone6+, it streams the iPhone6+ resolution which will be pretty high for theAP. If you try using an iPhone5 or iPhone6, you probably will see less lag. To reduce the bandwidth used, you might try to reduce the resolution ofthe camera that goes through the remote control. Regards,
Victor
Splashtop" This answer makes no sense to me
