Ronin mounting plate gets stuck and can't be removed from gimbal
17812 23 2018-6-30
psaad
Did anyone have a similar issue with their camera mounting plate (while setup on camera and inserted into gimbal)? Once you lock it into position and then unlock it, it just gets stuck when try to slide it out.
I managed to slide it out after a few forced tries and when i do there is a smell of burned metal...looks to me like the metal that locks the plate in place gets stuck on the plate and when i force it out it just detachs from it. Although. when i pass my fingers on the plate i dont feel like it damaged the plate.
I made a video to illustrate my issue... i don't know if its because im doing something wrong or if something is defective on my end:
https://photos.app.goo.gl/WzyRp2jNtVSczmnd6
This is really frustrating.
Any help would be appreciated!
Thanks!
Patrick
2018-6-30
psaad
Balancing issue with Ronin-s and a6300 with 16-50mm OSS kit lens
Hi,
I seem to be having alot of issues in balancing my a6300 with kit lens. I balance the tilt axis fine but when I can't seem to get the Vertical tilt to balance at all... its like i have to choose between the tilt axis being off or the vertical tilt being off! This is the first gimbal i try to balance so i expected a larger learning curve but im surprised that with such a light lens and camera im having more trouble then with a heavy one.
I made sure to add the riser plate but that doesn't fix the problem. I followed the dji ronin-s assembly tutorial but with no luck!
I made a video to show my process... any help would be appreciated!
https://photos.app.goo.gl/txzzw1Pj196q671v9
Thank you!
Patrick
2018-6-30
DJI Susan
Hi Patrick, we're sorry for the troubles. I'll forward to our engineers to see whether there are better suggestions or solutions.
2018-6-30
MichealMedia
Flight distance : 179026 ft
Remove the mounting plate, add some machine oil or plant oil on the block, then pull buckle on for several times, it will be good. This works for me.
2018-7-1
psaad
Michael, if I had the Ronin for several years then this would probably be the best solution. But I just received a brand new one and it started happening after I locked and unlocked just a few times. Not normal.
2018-7-2
btdigital
Same issues.  I just received my Ronin-S yesterday.  The plate got stuck.  I had to force it out.  Fortunately I had some oil from my hair clippers.  That hopefully will keep it from happening again.  Still, it's not an ideal thing to happen within the first day of receiving the product.  Also I have an a6500 with a 50mm, f1.8 lens and yeah it's been a pain trying to balance it with the camera facing upright.  I still can't get it to balance properly upright.
The only way I got even remotely close to balancing it properly was to add my Variable ND filter and an adapter ring for my 50mm lens for the added weight.  The problem is, I'd like to be able to use the Ronin-S and my camera for all situations and not just in broad daylight just so I don't have to worry about balance issues.  Would love to hear a solution for those of us experience balance issues who own lighter mirrorless cameras.
-Brian
2018-7-14
proimages
Flight distance : 1004731 ft
I add counter weights to get the full size Ronin in tune..and my latch has been sticking from day one..makes balancing even harder. If I tap it with a wrench it will unlock..Not been using Ronin much as the batteries died.
2018-7-15
MatejCeska
DJI Susan Posted at 2018-6-30 22:17
Hi! It happens to me too (plate getting stuck after every single locking of the plate). Its pretty annoying and I really scared that I will break something while Im forcing the plate to slide off again.
Any updates from engineers Susan?? Or should I just send it back for replacement?
Thank you!
Matej
2018-7-22
DJI Susan
MatejCeska Posted at 2018-7-22 22:03
Matej, sorry for the late response. I just got an update from our engineers that they suggested sending the unit in. You may start a case from here: https://www.dji.com/support Again, we sincerely apologize for the inconvenience.
2018-7-24
DJI Susan
MichealMedia Posted at 2018-7-1 23:21
Patrick, sorry for keep you waiting. Please refer the 9# and start a case to send the unit in. The local team will take care once the unit arrived.
2018-7-24
proimages
DJI Susan Posted at 2018-7-24 03:44
You know this is typical and the plate system that's on every Ronin is now going to trigger a return and blind review from DJI. Most of us are out of warranty. Maybe just the plate can be mailed in?
Shipping anything to DJI is risky my gear was lost.
Sad thing is these are professional tools being treated like a consumer toy. My entire Ronin and peripherals have been replaced, with weeks of down time and even more with trouble shooting issues.
Now both my batteries are dead and Ronin can't be used. These plates need an online solution or should be traded in due to defect, without loosing the equipment or risking it in transit. I hope others add to this!
2018-7-24
DJI Susan
proimages Posted at 2018-7-24 07:41
Sorry for the troubles. It is recommended to send the unit and plate together. We sincerely apologize for the difficulties during the repair period, this will be forwarded to the right team for further review. If you need any assistance, feel free to contact our support.
2018-7-25
oliver_s
Thailand
Hi Michael,
How did you remove the mounting plate?
2018-8-19
oliver_s
Thailand
Happened today during a professional shoot, the plate along with the camera got stuck on the Ronin S. Seeing as I have ten days before flying out for another project it will be interesting to see if this can be resolved within that timeline. Extremely disappointing, had the Ronin S for about a month now.  I've used another gimbal for over a year from a Chinese well known gimbal maker and something like this could just never happen.
2018-8-19
HybridPhotog
Philippines
I suggest for DJI to have an option to have replacements on their physical stores instead customers of sending/shipping the unit.
This will be a good solution to avoid having down time.
Waiting for a replacement / repair is frustrating.
2018-10-20
fansdf1ed11e
Hi everyone, it happened yesterday to me too on a professional shoot. It is quite annoying and frustrating.
It gets stuck everytime I lock it in.
Can dji send the replacement piece and then I send the defective piece?
I think is quinte fair since is causing a damage on jobs too.
Thank you
2018-11-6
djiuser_GKBIKMqEeWFa
So that little bar that click when you slide your camera on is in locked position so I can’t slide my camera in has anyone have this experience before?
2019-4-3
fans80534a2e
Flight distance : 305125 ft
Before you all send back to DJI, just try lubing it up.  I had the same exact issue, and put some lubrication oil (similar to WD-40) on the mounting plate, and now it slides in and out like a charm.  DJI's response is always 'send it in', but for something this simple, its much easier to fix it yourself.  By the way, the tiniest amount of lube will work-- I just put some 'liquid wrench' a paper towel and smeared the plate with the paper towel.  That way you don't get too much on there.
2019-5-10
Paul Furon
I’m having the same issue with the lock but not on the plate, at the handle level, the lock linking the battery to the plate.
Should I take it to a DJI CENTRE ?
2019-5-14
oliver_s
Thailand
Hi Patrick, I had the same issue and the solution is a very simple one. Metals requires some sort of lubrication. In my case I took the stick plate to a local DJI service shop in Bangkok and they sprayed some lubricant around key areas and this thing is smooth. Not sure what to recommend for DJI, perhaps there should be some maintenance instructions.
2019-5-19
fans89afa3aa
Having the same issue with the battery grip here. It won’t release at all. Stuck solid. Havnt used it yet. Just out of the box. Ridiculous really. Not sure what to do really.
2019-7-6
fans4b8b8f36
Ukraine
fans89afa3aa Posted at 7-6 02:39
Have you found out what to do? My battery grip is stuck also, can't get off
2019-7-18
fans4b8b8f36
Ukraine
fans4b8b8f36 Posted at 7-18 10:01
The thing is that the lever is turning fine but the grip itself is like glued to the gimbal now
2019-7-18
vpilic
Flight distance : 37039469 ft
Serbia
Hi all,
Which one of these two versions is newer one, and which one is older one?
Thank you in advance
2020-6-29
