Aardvark
Flight distance : 384432 ft
pfriel24 Posted at 2018-6-30 11:16
would that be the only solution? I intend to travel with this and my laptop, so if this would cause complications, I'd like a back up solution.
You can also update the P4 as Odan suggests using DJI Go 4 App. With all connected and powered up (and a Good wifi connection to display device), look at 'About' in 'General Settings' menu. From there you will see a 'check for update' option. Also take note of the RC build (this can't be updated from here).
Once aircraft is updated (V02.00.0700), If the RC is not at V1.9.3 (or at least V1.9.2) then it will need updating to allow it to communicate with aircraft properly.
The RC can be updated using the following:-
With RC and display connected (aircraft off), and display has a good wifi connection to internet. Run DJI Go 4 (V4.2.16 and above) and 'enter device'. Open the 'aircraft status' screen by tapping the screen at top edge where it says 'disconnected'. The top line 'Overall Status' should show if update required (this may take a minute or two to appear). When it does then tap on that and it should take you through the process to update RC.
Edit:- DJI Assistant 2 should run well enough on your laptop as well, fully charged batteries (Display, RC & aircraft) and a good internet connection via wifi is always best. You will likely need Assistant 2, as this is the only means of calibrating the VPS (Visual Positioning System (The front and lower cameras & ultrasonic transducers)).
