aburkefl
Flight distance : 78612 ft
I'm not "hooked up" at the moment, but I think it's in the camera settings. It works the same way in the Pilot app as it does in most cameras I've seen that have the capability. The name of the game is to "fill up" the display - if you don't get enough "fill" the picture will be underexposed and need brightening. If you get too much, the picture will get washed out - overexposed.
I'm very much an amateur photographer, but I think the idea is to use the histogram to "balance" how much light you're letting in. I think once you've used the histogram a few times it gets easier to understand what you should be doing.
On both P3 models, you can't change the f-stop, but you can alter the ISO and the shutter speed. Between the two of them, they can be very effective at helping set up the proper exposure settings. |
