HMArnold.msn
Flight distance : 24012 ft
I have an A2/Lightbridge/Futaba setup, with the signal from the Futaba going through a "Training Cable" on the back of the Futaba to the stereo plug on the bottom of the Lightbridge.
There is a setup sequence on the Futaba that lets you define the output channel for each signal, which includes joysticks and switches.
Make sure the signal you're tracking has a channel defined.
I would then use the Lightbridge Assistant to make sure all the signals make it that far.
If they don't make it to the Lightbtidge, the will never show up in the A2 Assistant. |
