I don’t have iPhone or iPad mini to connect with my Mavic Pro Platinum, and the only phone I can use is Huawei p9 plus. I was wondering the interference from phone call or social medium message, so I bought the expensive 5.5 inches CrystalSky. Definitely it provides a bright screen and is easy to use. It also prohibits to install any other applications, only allow to access DJI Go and DJI Go 4. It also has the own GSP. After used for about 15 times, I found that expensive monitor have several problems, I post here and share with the forum: 1. Screen frozen: It happened 3 time of 15 time of flights. Everytime it becomes normal when you restart.
2. The edge of CrystalSky is too high, some screen icons are located in the peripheral, so if you use your big fingertip to tap them, you need to tap times. I just wish DJI can update a new version with flat edge, like Samsung smart phone. 3. The sensitivity of the touch screen is not as good as iPhone. It has a little bit delay (this is not a big problem). 4. DJI Go 4 not response: When you give a command to the crystalSky, it showed “the Go 4 is not respond, do you want WAIT or Restart?). That’s very weird, especially when you work on video or photos. Definitely the price is too high. A 5.5 inches CS is 469 dollar, but a 59 inches Philip 4K smart TV is only 250 dollars. I wish DJI can adjust the price to 200 to 250 for 5.5 inches, 300 to 350 for 6.8 inches. We also need to buy a 69 dollars of Mount bracket. Wish DJI can provide a package which includes the bracket. |
