How to increase bit rate of movies in DJI GO?
1879 9 2018-7-2
alex_markov
Flight distance : 39244380 ft
Bulgaria
I both Osmo mobile 2 for long EU travel and besides several annoying bugs it's a great product - but DJI Go is frustrating I can't find any settings besides resolution for movies and they are so Overcompressed that the sky is Unbearable   Please Help how to increase the bitrate? Or use H265? I have tried to use standard photo app but cant make record button work?
2018-7-2
DJI Wanda
Hello there. We apologize if you're having some issues. What do you mean by overcompressed? Did you try to reinstall the app? Do you have a screenshot showing the problem?
2018-7-2
alex_markov
Bulgaria
DJI Wanda Posted at 2018-7-2 04:54
You can clearly see a pixelated sky in above footage and in some cases it's even worse - phone is HTC U11 if it's important
2018-7-2
DJI Wanda
alex_markov Posted at 2018-7-2 05:11
https://youtu.be/YTM2_IjsjT4
I see. Did you try to use a different mobile device? Because the mobile device that you're using is not listed in the compatible devices for Osmo Mobile 2. You can check it here: https://www.dji.com/osmo-mobile-2/info#downloads
2018-7-2
alex_markov
Bulgaria
DJI Wanda Posted at 2018-7-2 05:28
[view_image]
I just tried with Samsung S9+ and it's OK , shame HTC U11 has this problem with the app
2018-7-2
DJI Wanda
alex_markov Posted at 2018-7-2 05:45
I understand and I apologize for the inconvenience. One of the reasons why we have this list of compatible devices is because there are some phones that do not meet the required specifications for a specific unit.
2018-7-2
alex_markov
Bulgaria
DJI Wanda Posted at 2018-7-2 05:54
Ok, is there the way to make shutter button work with standard camera app?
2018-7-2
DJI Wanda
You just have to open the standard camera app.
2018-7-3
alex_markov
Bulgaria
DJI Wanda Posted at 2018-7-3 05:56
I did this but rec button on Osmo is not triggering record on the standard app as it does on DJI GO
2018-7-3
DJI Wanda
alex_markov Posted at 2018-7-3 06:06
Yes, that's right. If you're going to use the standard camera for your Osmo Mobile 2, it will serve as a gimbal only. For records or capture button, it will be manually.
2018-7-3
