KedDK
Flight distance : 1133038 ft
Denmark
DennisM Posted at 2018-7-2 17:52
Same happened to me on my plus + v2.0. It worked for me after I went to the settings and disconnected from my home wi-fi, turn off the controller then on again, then reconnected to the home wi-fi. Very frustrating indeed. I think when you reset it the controller needs, for whatever reason, to find an unconnected wi-fi signal then have you set up wifi portion from scratch. I know it sounds stupid but it worked for me. Good luck>
Why does it sound stupid?
That is the whole purpose of doing a reset, stupid would be if all kind of customized settings was still in place after a reset.
The big issue on the + controllers is that it is not obvious for the non experienced to locate and setup the wifi configuration again. When closing the error message it simply should enter the settings section for the user to verify or setup the settings again. |
